MTH simple question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 4th, 2005, 03:21 AM
DarkMiniCooperS's Avatar
MINI crazy!
Send a message via MSN to DarkMiniCooperS
Local Time: 03:22 PM
Canada
MTH simple question
Hi,
I've had MTH loaded for more than 4 months now and I love it!
I have a simple question...
My MCS has ECU version 38 and I got MTH for that version.
If the dealer would flash my ECU to an updated version without my knowledge, would I still be able to install back my MTH flash that I had before and still use it??
I know this would erase the new BMW map but would it work??
2012 Countryman S All4 - Light White, Sunroof, Premium & Cold packages, Xenons, Adaptive lights, and lots of fun!!
Old Jan 4th, 2005, 03:47 AM
Hartge's Avatar
SuperSoniC
Local Time: 04:22 AM
Malaysia View Hartge's Electric Blue & White 1st Gen MINI Cooper S Profile
yeah, I would like to know about that too... anybody?
Old Jan 4th, 2005, 03:56 AM
MINI crazy!
Canada
Hartge, does my question sound clear to you??
If not, could you re-write it in a "better" english since english is my second language...
Old Jan 4th, 2005, 04:32 AM
Hartge's Avatar
SuperSoniC
Yes mate, loud and clear.
Old Jan 4th, 2005, 04:57 AM
MINI crazy!
Canada
Great! I hope someone will be able to answer it!!
Old Jan 4th, 2005, 01:28 PM
PlickBadger's Avatar
Local Time: 02:22 PM
I believe it depends on the base version of software. In your case I think reloading the v38 maps over v39 would work because there's supposedly not much difference between the two base versions. If you were on v36 with MTH mappings and the dealer installed v38 or v39, I don't think the v36 mappings would work too well if at all as there were a bunch of changes between v36 and v38/39. There is also a compare function in Cartune that you can use to determine whether the dealer upgraded your car. I'm pretty sure this information is fairly accurate. I'm going by what I've seen work in our local MINI group.
Old Jan 4th, 2005, 02:18 PM
Hartge's Avatar
SuperSoniC
I believe that compare function in the cartune software is used to compare the installed map with the map that you are about to install. Lets just say you have 2 files, first without exhaust mod and second with exhaust mod. You have installed the 1st file and try to compare it with the second file( both same version), I believe there will also be an error msg popping out even they are in the same version.
So this function cant be used to determine the version of the ECU. Correct me if im wrong. thank you.
Is there any problem with V39 and above?
Old Jan 4th, 2005, 02:34 PM
Yes you're correct. The compare function is used to compare the installed map against a map file. I've used it several times. It won't generate an error if the loaded map and the map file are the same. However, it cannot be used to determine full ECU version. There's quite a few threads on people having issues with v39, but most of them seem to revolve around not resetting the adaptive learning cache after the upgrade.
Old Jan 4th, 2005, 04:25 PM
Hartge's Avatar
SuperSoniC
Are you saying that they dont flash the latest version after they load the MTH files?
Old Jan 4th, 2005, 04:51 PM
I'm not sure what you're asking
Old Jan 4th, 2005, 05:53 PM
MINI crazy!
Canada
Another question,
Is it possible to flash back to a stock file (let's say version 38) if the dealer would put the version 39??
Old Jan 4th, 2005, 06:38 PM
CoryB's Avatar
Local Time: 04:22 PM
United States Male
Quote: Originally Posted by DarkMiniCooperS
Another question,
No, because MTH only addresses a few areas of the ECU map, not the entire thing.
As for updating/backdating, why not just download the v.39 ECU file and send it to Franz? He can update that - I had mine done several months ago.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Jan 4th, 2005, 06:40 PM
Another question,
Once the dealer has updated your software, you cannot flash back using cartune. The files downloaded and uploaded via cartune are only mappings not the entire ECU
Old Jan 4th, 2005, 09:43 PM
MINI crazy!
Canada
Ok great!
Thanks for the answers..
Does the Version 39 with MTH is good or it feels jerky like Version 39 from BMW??
  #15 (permalink)
Old Jan 6th, 2005, 07:02 PM
Hartge's Avatar
SuperSoniC
well, nobody knows?
Simple ICE question - need simple answer for simple guy... Benfrain First Generation Interior & Ice 4 Mar 29th, 2005 12:37 PM
simple question! piston Delivery, Shipping & Order Tracking 5 Aug 10th, 2004 08:48 PM
Quick simple question! Phil321 First Generation Interior & Ice 1 Apr 10th, 2004 05:43 PM
Simple Question Mini Mims General Discussion 15 Apr 13th, 2003 12:48 PM
