CNC cylinder HEAD WORK ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 3rd, 2005, 06:16 PM
supercharged99's Avatar
clinton steenkamp
Local Time: 05:49 PM
United Kingdom Male View supercharged99's Classified Ads
hi all.
anyone gone down the route of some head work ?
i am looking at installing a cam (any decent ones out there ?) and getting a top company to do some head work.
schrick seem the best so far as to the cam .
thanks
c
yeeeeeehaaaaaaa
DAMN THIS THING IS QUICK
Old Feb 3rd, 2005, 08:29 PM
MINI 2 Sponsor GT Tuning
Local Time: 06:49 PM
United Kingdom View roland2003's Classified Ads
CNC Milled Out Ports.
Although not quite ready yet,we will be including this with our stage 2 (and to follow around
May) stage 3 head work. Certainly no one else does (or is likely to do) this on the Mini.
We will be generating some quite complex cutter paths that start way down the port
and go through a 'smooth profile transition' , ending up at the manifold gasket face with the exact shape/ position /size of the gasket ( like within .002" or 50 microns!)
This is true 3D milling using long series 10mm ball nose cutters. This degree of 'perfection
in porting' is impossible to achieve by hand. We tried to do it by hand on the head of our
demo car,and although good it took 100 hours! and still not as good as milling it.
Of course there is still much hand porting to be done in the throat areas.
Once we have one completed it (March) I will put up a piccy (close up) of the portwork.
Best Regards Roland Gt Tuning
Old Feb 5th, 2005, 10:29 AM
clinton steenkamp
will you be re-shaping combustion chambers?
if you are doing larger exhaust valves,how much bigger are they and are you cutting back the valve heads ?
have you found any decent cam shafts ? (i went to the NEC in Birmingham , and spoke to a member of the SCHRICK team from GERMANY.they do the best cam i have seen,and was told that a vernier pully was not needed for their cams . only problem is i cannot buy direct.they only supply if you own a garage?????
thanks
clinton
yeeeeeehaaaaaaa
Old Feb 5th, 2005, 08:01 PM
Hi Clinton, yes there is some tidying up of the combustion chamber,the basic shape is fine though. There is also work on the valves,in fact the stage 3 will go beyond 'thinning out',
but is a little way off completion at the moment.
Regarding the vernier pulley /cams I will put a thread up explaining why adjustable cam timing is beneficial (even on a Schrick cam as if the brand should make any difference!)
Cylinder Head Aberdeen Al First Generation MINI Tuning 15 Oct 4th, 2007 02:18 AM
JCW Cylinder Head carreracat First Generation Works 7 Dec 20th, 2006 05:38 AM
Cylinder head Fisher First Generation MINI Tuning 5 Dec 10th, 2005 06:13 PM
How heavy is the cylinder head? Hubert First Generation MINI Tuning 3 Jan 22nd, 2004 01:15 PM
