Octane Ratings explained - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 15th, 2005, 07:21 PM
MINI 2 Sponsor GT Tuning
Local Time: 09:02 PM
United Kingdom View roland2003's Classified Ads
Hi Guys, here is some easy to read info on octane ratings for all.
OK , Octane is a fuels resistance to 'knock' .The higher the number the greater the resistance. Knock is very undesirable as it is the point where the fuel is no longer burning
in one controlled direction (moving from the plug) but self igniting causing two flame fronts to collide.
Octane can be measured in 2 ways ,both using very slow speed single cylinder engines. MON tests at WOT, whereas RON tests at half throttle. Because of this ,logic
suggests that a good MON figure is more important to us than the RON figure,as you
dont race on half throttle!
In the UK and Europe our fuel at the pumps is rated as a RON figure. As a general rule the RON figure is about 8 higher than the MON . Therefore 98 RON 'Optimax' is around 90 MON.
In the US they use 'AKI' which is the average of the RON and the MON . Therefore what we
call 98 they call 94.
AFAIK the highest octane unleaded race fuel possible is circa 106 RON / 98 MON.
With leaded fuels the RON can go to almost 130 ! . If you run leaded you will murder the
cat and the lambda sensors tooso dont do it.
So why bother with high octane if the timing can be retarded to prevent knock?
OK, the 3 variables which can be increased if we utilize more octane are;- compression,
boost pressure,ignition advance,or any combination of these. Assuming everything else is ok,all 3 will increase power.
Im sure there's loads more I've missed but my brain is now a total void.
Regards Roland Gt Tuning
Old Feb 15th, 2005, 07:29 PM
rasp's Avatar
The Mini Family Sponsers
Local Time: 08:02 PM
England View rasp's Dark Silver & Black 1st Gen MINI Cooper S Profile
Interesting!...thanks...
Old Feb 15th, 2005, 08:57 PM
Wobert's Avatar
Mr 120d Sport
United Kingdom Male View Wobert's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile View Wobert's Classified Ads
RON = Research Octane Number
MON = Motor Octane Number
Yes?
Old Feb 15th, 2005, 09:09 PM
I've got a drum of Cool Blue 106Ron fuel in my garage. Might stick it in and see how she goes .... or blows
Old Feb 15th, 2005, 09:33 PM
RallyMINI's Avatar
This guy knows even more...
http://www.geocities.com/TimesSquare...6/octane1.html
This guy explains the actual engine used to test octane, and has links to several historical sites related to Octane engines... pretty neat.
Thanks for bring this up, I learned something new today!
RMout
Drive Fast! Drive Sideways!
Old Feb 16th, 2005, 06:14 AM
Wobert Thats correct
LordNikon Yes give it a go,and let me know what you think. TBH Ive never tried race fuel
in the Mini.I might get some but is expensive ,its ok for a Kart or M'Cycle which uses alot less fuel.
Regards Roland G T Tuning.
Old Feb 16th, 2005, 07:06 AM
Best Personal Regards
Local Time: 10:02 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
Using higher octane in an engine that is not tuned for it is a waste of money. It will essentially do nothing. The beauty of higher octane fuel is that you can use a higher compression ratio and or advance the timing significantly both of which will make the engine generate more power, quicker.
Old Feb 18th, 2005, 09:11 PM
RedUn's Avatar
MUGEN POWER
Japan Male
so basically........higher = better
Old Feb 18th, 2005, 09:46 PM
jlm
Local Time: 03:02 PM
consider this:
it takes a bit of time for the compressed charge to ighite and develop full pressure in the combustion chamber. the point of spark advance is to give the pressure enough time to build so it pushes most efficiently on the piston just as it starts down after TDC. As you increase octane, you are inhibiting knock but also slowing down the burn, therefore you need more advance with higher octane fuel. It is not always true that more advance means more power; the advance needed is corellated to the burn time and octane rating.
john
Old Feb 19th, 2005, 03:19 PM
You can run retarded timing or normal timing with high octane fuel and there is no deleterious effect. If you want the benefit of higher octane you must advance the ignition, period, end of story.
Old Feb 20th, 2005, 07:14 AM
Babes's Avatar
Cruising In The Minge
Local Time: 04:02 AM
Australia Male View Babes's British Racing Green & White 1st Gen MINI Cooper S Profile View Babes's Classified Ads
What about fuel additives? are they worth while putting in or only if the car has been set up for higher octane as previously mentioned?
Jason
2003 BRG/W JCW MCS - 2002 PS/PS JCW MC - 1970 BRG/W MK2 Morris Cooper S - 1964 Blk 850 (eaton supercharged 1293) - 1961 Morris Traveller - 1974 Ex Army Moke - 1978 1275 LS
Old Feb 20th, 2005, 07:55 AM
Octane boosting additives are worthless. (See above)
Things that can be useful are valve and injector cleaning additives, specially if you are into using plain gas and not premium. BMW dealerships sell a valve cleaning additive that is the bees knees, thoroughly proven and thoroughly effective.
All US gasoline is sold with additive (though Regular has a minimum mandated content) while there is no obligation to use additives in Europe or the rest of the world----y'know, all them people worried about global warming and Kyoto can't be bothered to mandate a "known to work" emission mitigation technology
Anyways, off the soap box.....all premium grades the world over (reputable brands) contain very effective cleaning additives.
Gas Octane Ratings Tazminia Maintenance & MINI Care 8 May 20th, 2005 04:05 AM
