| The extra intake is to increase airflow at high revs, having it open all the time would cause the car to have too much oxygen all the time. That would decrease your mpg and likely cut performance - it would be like running a Honda with the VTEC stuck in high lift mode. 1967 MK1 Mini 'SPOM' : Picture of SPOM 2009 JCW Mini Cooper S... Delivery December 2008 2009 Cooper Clubman... Collected 11th November 2008... Lovely |
| Would it not just be like running with an normal after market Cold Air Intake? Performance and MPG would be comparable to a similar after market CAL, like an ALTA or K&N? I've heard of people having the flap fixed open at the MINI dealer to achieve the noise at all engine speeds. Does the flap opening and closing simply allow air to come in from the windscreen air inlet. James - "The Rogue" - DS/W MCS |
| It will not cause it to have "too much oxygen", the engine only sucks in what it needs after all. It will make it a little easier to breathe in lower revs. The flap is there to keep things quieter at low revs, that's all. I have thought of adding a switch as well. It is apparently just a solenoid so it should be relatively easy to add wires to and switching on for short periods of time. Not sure if it's something that you would always want to leave open as it may wear out the solenoid. But for a short time like autocross run or 1/4mi drag it certainly makes sense. It may however be easier just to remove the physical flap for your racing day. I'll have my intake at the end of the month and I'll investigate then. |
| You can have a lean mixture, which means you have too little fuel for the air charge available, making the mixture very volatile, very hot and prone to melt your pistons. Is it too much oxygen....well, for the amount of fuel available in the charge it is. would it happen cuz of some flap....doubt it. It would only happen cuz there was a fault in the computer or an air leak AFTER the sensors. Hope this helps |
| Help required: JCW intake installed. Flap not opening above 4500rpm | AUSMINI | First Generation MINI Tuning | 17 | Apr 9th, 2008 04:14 PM |
| JCW seats with airbag de-activation switch | Lucky Dave | First Generation Interior & Ice | 4 | Mar 26th, 2006 03:20 AM |
| JCW intake flap | tlamano | First Generation MINI Tuning | 3 | Jan 19th, 2005 10:01 PM |
| JCW Intake on std MCS : Manually alter flap opening rpm | john_o | First Generation MINI Tuning | 9 | Dec 23rd, 2004 03:51 PM |
| ASC+T (Traction Control) Switch? | matt.morrow | First Generation MINI One | 32 | Aug 11th, 2002 03:53 PM |
