| rear wheel drive mini...disadvantages? I'm considering building a rear wheel drive mini with the engine in the boot, and I was wanting to hear of any reasons why having the enging in the boot with rear wheel drive would adversly affect the handling qualities of the mini. Some things I could think of would be that there would be much less weight up front over the tires and perhaps wouldn't track as well through the twisties? Which could also be a good thing because understeer is easier to correct. (IMHO) Also making it rear wheel drive with a high output of power could cause the rear end to slide out a lot if one is not careful with throttle coming out of the corners. "Of course it could be a lot of fun too." Are there any other disadvantages that one can think of? Handling wise. Thanks Joshua |
| that "lower moment of inertia stuff" sounds neat, but unless you really know what you're doing, you could end up with a car that handles way worse than the stock car. short wheelbase mid-engine cars are notorious for trailing throttle snap oversteer, the fiat x1/9 and first gen mr2s being prime examples. before you start this, take a stock 1st gen mr2 into a parking lot and drive close to the limit in a circle at about 60 mph with moderate to high throttle. then snap off the throttle and see what happens. and this car had a whole engineering team behind it! but good luck if you try this and be sure to keep us posted! |
| Hmm. Sounds like a stupid idea. The Porsche 911 has taken many years of engineering skill to make it work, something i can't see a guy in a shed having (sorry). If you took a 911 and removed the electronic safety nets it would be a handful again. Personally i don't get on with 911s, the front has no weight (duh) so turn in feels a bit weird, something i can't get used to. The Clio V6 is a different car from the other Clios, it does not share any major mechanical part..its not an adaptation. The Mk1 was engineered to understeer because it was so hopeless, and therefore dangerous in the wrong hands. Awful car in just about every way, and i'm a Renault fan! -Rob |
| Your best bet would be to build a space frame tube chassis, mount the engine in the front and have a transaxle for a diff in the rear. That would get you close to the 50/50 weight distribution you would need for it to handle well. while you're at it, seat yourself in the middle. Surely you could fab the body out of aluminium or even carbon fibre. Of course if you are actually thinking of getting a stock MINI and turning it into some sort of a big Smart car, good luck, let us know who you're getting on from time to time.......sure hope you know how to weld well and your trig is not too out of date. |
| Isnt the best balance Front engine, Rear wheel drive?? The engine in the back will put nearly all the weight and the rear and the car will probably understeer like crazy. But, it will have better rear wheel traction and so have faster acceleration. improve one area always worsens another. Good luck though! Should be fun....I'd day go for four wheel drive and front engine pushing 300bhp |
| What you ultimately want is a mid engine, all wheel drive car, engine ahead of the rear axle, so some of its weight gets transferred to the front, a front diff, fuel tank and battery also on top of the front axle and the driver compartment cheating towards the front. 6 billion horsepower should help as well |
| I've heard the 911 platform describes as a bad idea engineered to perfection. As I understand it, turn in is all brake application / release timing and weight transfer.. |
| MINI Cooper S rear wheel drive conversion | motaica | Future Variants | 11 | May 17th, 2007 01:02 PM |
| All wheel drive MINI? | Dutchy | Future Variants | 22 | Jun 19th, 2004 01:13 AM |
| Rear wheel drive cooper??? | L8 Apex | First Generation MINI Cooper | 4 | Jan 25th, 2003 04:31 PM |
| Future All Wheel Drive MINI | Cape Cod MINI | Future Variants | 12 | Jul 24th, 2002 12:11 AM |
| BMW: Rear-wheel-drive! | Jakx | General Discussion | 8 | Jun 6th, 2001 06:14 PM |
