which after market intercooler to get - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 28th, 2005, 07:15 PM
Munnster's Avatar
I love my mini
Local Time: 06:30 PM
United Kingdom View Munnster's Dark Silver & Black 1st Gen MINI Cooper S Profile
my MCS is at 215bhp after being tuned by west tuning, now i want to get a bigger intercooler to deal with the hotter boosted air, which one would you recommend ????
ive been looking at the forge motor sport one for £375 polished
Old Mar 28th, 2005, 07:32 PM
minibee's Avatar
GP 1752
England Male
link here for info
http://www.mini2.com/forum/gt-tuning/87743-new-gt-tuning-intercooler-diffuser-1st-pics.html
Neil...
Old Mar 28th, 2005, 07:33 PM
Best Personal Regards
Local Time: 08:30 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
I liked dealing with Graham at GR Sport, and I did a little research on him before I got the unit. He definetely has the experience and knows his stuff. Have yet to install it though, as I am not one to believe in numbers other than my lap times.........
Hope this helps.
PS: Are you sure it is 215 and not 217??
Old Mar 28th, 2005, 07:51 PM
Send a message via MSN to GRSmotorsport
Local Time: 07:30 PM
United Kingdom View GRSmotorsport's Classified Ads
Remember to add vat to the price above, if you're buying the Forge unit.
My intercooler is the only one thats had extensive testing, ie rolling road, road tests and deserting early this year in the USA, all testing done were comparing the original unit against the GRS, and came out with very good results. Its the same thickness as the original, but has a bigger surface area with well designed end tank.
Graham
Old Mar 28th, 2005, 07:58 PM
RallyMINI's Avatar
Quickly, I'd say that this one is the bees knees if you have $$$ to burn...
http://www.webbmotorsports.com/performance.php
Scroll down to the front mount intercooler!
Really nice...
RMOUT
Drive Fast! Drive Sideways!
Old Mar 28th, 2005, 08:42 PM
rasp's Avatar
The Mini Family Sponsers
England View rasp's Dark Silver & Black 1st Gen MINI Cooper S Profile
I have the GRS Intercooler and Ray at West Tuning says its the best one his tested to date...
ID:	74452   Click image for larger version
Name:	DSC02244 email.jpg
Old Mar 29th, 2005, 06:50 AM
supercoopers's Avatar
United Kingdom View supercoopers's Classified Ads
Fom personal experience, I would say steer clear of the Alta unit. Overpriced and poor overall quality compared with the likes of units available from GT-Tuning and GRS motorsports for example. You are lucky in that you live in the UK, so in fact the choice of quality intercoolers for the MINI is pretty extensive. The GTT is the largest Air-to-Air intercooler currently out there, being 16 tubes length-ways. It also has a very precise fit and finish.
Check out:GTT intercooler
The intercooler is the product right at the end.
Recent GTT intercooler thread
You will also find that Forge builds alot of intercoolers for tuning companies to their spec. They can also custom fabricate any intercooler and diffuser that you want by going direct, but it doesn't save you any money unless you know someone who works there of course...
Cheers,
Henry
Old Mar 29th, 2005, 09:12 AM
Munnster's Avatar
I love my mini
do u need the oil catch when fitting the intercooler ??? should be ordering mine from grs end of the month
Old Mar 29th, 2005, 02:57 PM
rasp's Avatar
First of all..Good Choice...
Yes its a good idea to use an OCC but and I cant stress this enough..DO NOT use the Alta one like I did because it leaks air all over the place...Now I am waiting for the GRS to be finnished to go with the IC....Come on Graham get your finger out..
Old Mar 29th, 2005, 05:22 PM
Cheers,
Henry
Henry,
What you have to realise is not just how many tubes are being used, but how the core is constructed and the type of tube used . This is 50% of the total efficiently of the intercooler, the other 50% is end tank design.
I only use vacuum brazed core’s and nothing else, why? well vacuum brazed cores dissipate the heat better. The vains are brazed to the tubes and then brazed to the end plates These are more expensive to manufacture because of the process involved but worth it!
The other type of construction is to ‘glued’ version, these are cheaper to make, and are less efficient, why? The glue holds the heat in and doesn't’t release to the atmosphere as quick. The usual method is to glue the vains to the tubes, then the end plates are hand welded to the tubes, if these were glued the glue would melt when welding the end tanks on
My intercooler was tested in America against a larger version well only an 1” deeper in the desert this year the result showed that my intercooler was as good as the very slightly larger version….
Here's some interesting reading on types of core's and good and bad end tank design.
http://www.are.com.au/techtalk/intec...%20AIR%20FLOW*
Graham
Old Mar 29th, 2005, 07:57 PM
RedUn's Avatar
MUGEN POWER
Japan Male
Quote: Originally Posted by GRSmotorsport
Henry,
shame was just about to say the same
Old Mar 29th, 2005, 09:58 PM
Henry,
Very informative Graham. Thanks for clearing that up for me
And also congrats on the desert testing results. That's a mighty fine achievement and it's good to see that your intercooler works well in possibly the harshest hot environment on earth!
Cheers,
Henry
Which intercooler do you have? Damo First Generation MINI Tuning 12 Aug 17th, 2007 10:16 AM
What intercooler do i go for Ant FR First Generation MINI Tuning 4 Jun 12th, 2007 10:58 AM
Intercooler Ven0m First Generation MINI Tuning 9 Oct 31st, 2006 11:01 AM
New vs. Old Intercooler Mike Edwards First Generation Works 9 Sep 3rd, 2006 02:12 PM
Large Intercooler / Closed Intercooler GTT 280 First Generation MINI Tuning 7 Aug 22nd, 2005 10:06 PM
