Oil Pressure Light After Oil Change - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 16th, 2005, 03:10 PM
Local Time: 01:50 PM
Angry Oil Pressure Light After Oil Change
We changed the oil on a 2004 Mini/Auto Trans and the oil pressure light came on at restart. We have removed and reinstalled filter, attempted to reset computer. Any ideas or comments?
Old Apr 16th, 2005, 03:19 PM
Best Personal Regards
Local Time: 07:50 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
Does it stay on after say five minutes idling? Any leaks?
Old Apr 16th, 2005, 03:22 PM
No we have not left it runnung, but we will try and reply.
Old Apr 16th, 2005, 03:40 PM
Ran the car for five to operating temp and still have oil pressure light.
Also, attempted to reset service interval and get "test" and 51A rather than 15A. RST does not appear in left corner.
Old Apr 16th, 2005, 07:03 PM
OK, Houston we got a problem. How about the oil pressure sender connnector? Have you checked that it has not come undone for some reason? It should be to the left of the oil filter. Of course I am assuming the oil level is good, right?
Also, you are positive that you installed both the plastic sleeve and the spring within the filter cannister?
Old Apr 18th, 2005, 12:02 PM
Smile Oil Pressure Light Resolved
Thank you for the input.
My wife dowloaded the instructions for the Cooper S and threw away the plastic sleeve with the filter. ProMini's web site had a warning for the Cooper's, I found the sleeve, installed it and no Oil Pressure Light.
Old Apr 20th, 2005, 02:50 PM
I am very, very glad you resolved the issue and more importantly, that you did not damage the engine.
Idle oil Oil pressure 0 psi!!!!! acebedof First Generation MINI Tuning 4 May 29th, 2006 03:20 AM
Oil pressure warning light flashing S1.6 BJD First Generation Faults & Fixes 2 Jul 21st, 2005 10:56 PM
intermittent oil pressure light flyboy2160 First Generation Faults & Fixes 1 Jun 8th, 2005 08:49 AM
Oil Pressure Light after Oil Change tpwmini First Generation Faults & Fixes 0 Apr 16th, 2005 03:46 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
