Dyno results - what to do next? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 22nd, 2005, 05:39 PM
indimini's Avatar
Send a message via Skype™ to indimini
Local Time: 12:50 PM
United States View indimini's Cool Blue & Black 1st Gen MINI Cooper S Convertible Profile
I just had my 05 MCSC dyno'd at Mt. Airy Motors (in Maryland) on a Mustang 1750 dyno. My car has a 15% pulley, ProMINI CAI and AmD One-Click software.
Environment was about 60 F and 90% humidity.
My peak HP was 136 at the wheels, and max torque was 124 lb-ft. These numbers seem low to me considering the mod's done to the car.
The engine HP climbs solidly up to 6400 RPM.
What is particularly troubling is that the torque drops dramatically between 4,000 and 5,200 RPM, corresponding to a drop in the AF ratio. Torque maxes @ around 4,000 RPM (124 lb-ft) and is down to 115 lb-ft at 5,200 RPM.
I'm curious to know if that drop off is typical or if I should consider dropping the AmD software and go the Unichip route.
Honestly tuning is new to me so any input/thoughts is greatly appreciated.
Old Apr 22nd, 2005, 05:46 PM
CoryB's Avatar
Local Time: 01:50 PM
United States Male
My first guess would be that the ECU mapping is either corrupt or just inaccurate. Why not return it to the stock mapping and re-dyno to see what you get?
With a 15% pulley and CAI you don't HAVE to have a remap, so try it that way first and see what happens.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Apr 22nd, 2005, 06:40 PM
indimini's Avatar
I am thinking I should schedule another run with the stock program. They disconnected the battery prior to the run in order to install an 02 sensor in front of the cat -- is is possible that either caused the ECU remap to be lost causing the ECU to revert to the stock program?
Old Apr 22nd, 2005, 08:01 PM
CoryB's Avatar
United States Male
Disconnecting the battery would clear the adaptive memory that learns how you drive. But it won't affect the actual ECU flash program.
In fact, some people always reset the battery before dyno runs to eliminate the variable caused by the adaptive memory.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Apr 22nd, 2005, 10:29 PM
While possible this is not always true and generally does not reset the adaptations
Old Apr 24th, 2005, 09:48 PM
shazam's Avatar
Local Time: 05:50 PM
United Kingdom View shazam's Dark Silver & Black 1st Gen MINI Cooper S Profile View shazam's Classified Ads
Was there a big fan to feed the intercooler- if not the system will not reflect on the road performance i recon.
Old Apr 24th, 2005, 10:21 PM
indimini's Avatar
They did have a big fan that they used after the first pull. I did wonder if that could be one of the issues. I thought I'd read somewhere for example, that the BMP CAI benefits aren't seen w/o the airflow simulating the road conditions.
Old May 1st, 2005, 08:54 PM
MINI-Morgan's Avatar
MINI Obsessed...
Local Time: 06:50 PM
sounds like it isnt being fueled right..... ECU map problem or somehow blocked injectors. You are using 97/98 Octane fuel right?
Old May 3rd, 2005, 02:26 AM
United States View aquaanox's Hyper Blue & White 1st Gen MINI Cooper S Profile
im getting the exact same upgrade done tomorrow, on a 05 mcsa however) 15%
and BMP Promini intake. Did you ever figure out what the problem was with the dyno results ?
Old May 3rd, 2005, 02:36 AM
indimini's Avatar
Not really. One possible (major) problem was that there was very little air flow to the CAI and SC during the dyno. I think it may not be a fair test to have run with a small box fan -- there's no way that the fan could reproduce the air flow being forced into the engine bay you'd see in real world conditions.
I also may have a leak around the intercooler -- there were some very odd noises coming from the car the other day that may be an indicator of such a problem.
I noticed you are in the DC area. Where are you having the pulley installed or are you doing it yourself?
Old May 3rd, 2005, 02:57 PM
Getting it done at Towson, bought the parts from sterling. Towson is my dealer but they didnt have the parts in stock and they are backordered on mini mania.com.
Old May 3rd, 2005, 03:02 PM
Paul's Avatar
MINI2 No.1
England Male
Also consider that some maps, pulleys, intakes and exhausts may not all get along. I'd imagine that if a map is designed for car without a pulley, or without an intake, or both, then it may not give the best mix for a car with a smaller pulley and/or intake (for example).
Old May 3rd, 2005, 05:17 PM
MINI Obsessed...
I've heard that the intercooler seals can leak under heavy boost and in some cases come off....but not confirmed.
Old May 3rd, 2005, 09:56 PM
Its done! See my review in the MCSA forum..
~thanks for the info here all.
  #15 (permalink)
Old May 4th, 2005, 05:26 PM
s_and_m's Avatar
220 of your finest horses
Send a message via MSN to s_and_m
England Male View s_and_m's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
It ain't an exact science
Try sticking your hand out of the window at 6000 rpm in 5th - it creates a bit of drag. Now consider if the the fan placed in front of your car during a dyno run could create the same effect.
Temp, dyno settings, airflow, humidity, altitude etc will have an impact on your figures. 136 at the wheels sounds like approx 160 at the flywheel.
S
MC Dyno Results Step_7 First Generation MINI Cooper 28 Oct 11th, 2006 12:11 PM
dyno results SMG First Generation MINI Tuning 35 Jun 26th, 2003 12:31 PM
Dyno results Mini S First Generation MINI Tuning 5 Jun 7th, 2003 01:37 AM
MC Dyno results ddp First Generation MINI Tuning 12 Dec 29th, 2002 10:04 AM
Dyno Results macncheese First Generation MINI Tuning 43 Jul 23rd, 2002 05:43 AM
