| Hi Gr1zzLy. The popping sound is a feature on the 2005 Cooper S and is completely normal. Nothing to worry about there. Now that you know it's nothing bad, I'm sure you'll most probably learn to love it. If the sound you are referring to regarding the gearbox is what I am thinking of... then that's normal too. The harder and faster you change gears, the more likely you are to hear the gearbox working. If you're still not sure that it's normal, get it checked out by the dealer. The MCS's gearbox generally isn't know for being problematic to my knowledge. Hope this helps. SuperCharged |
| Thanks supercharged... you put my mind at ease. The popping noise does sound kinda funky, but you can probably understand my nervousness considering that there have been quite a few problems with minis in the past. Having just got it last Friday I was very nervous that mine might have some of the problems as well... |
| 1st Gear to 2nd? | Jonny H | First Generation Faults & Fixes | 5 | Nov 9th, 2006 01:50 PM |
| Crunching noise when going from 1st to 2nd | sam_pd | First Generation MINI Cooper S | 10 | Oct 21st, 2006 06:12 PM |
| hard to get 1st and 2nd gear | Richy777 | First Generation MINI Tuning | 1 | Mar 26th, 2006 06:06 AM |
| Getting a "clunk" under the car when shifting from 1st to 2nd | dave316 | First Generation MINI Cooper S | 8 | Apr 26th, 2005 05:17 PM |
| Noise shifting from 1st to 2nd | grafiksguy | First Generation Faults & Fixes | 5 | Aug 4th, 2003 01:36 AM |
