How does this valve train stay in adjustment? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 4th, 2005, 06:38 PM
Local Time: 11:12 AM
United-States How does this valve train stay in adjustment?
I pulled off the valve cover to see what I would be up against, should I change to a more performance oriented cam shaft. I see that the rocker arms have rollers that ride directly on the cam lobes and the valve actuating end has what appears to be an oil seal on the tip, but I don't see what keeps it all in tolerance. What keeps the valves from being held open by a tight rocker(valve actuating) arm? I see no adjustment and no hydraulics. Please enlighten me! -Jeffy.
Old Jul 4th, 2005, 07:45 PM
supercoopers's Avatar
Local Time: 05:12 PM
United Kingdom View supercoopers's Classified Ads
The MINI head runs hydraulic tappets I think you'll find...
Sorry I can't be of more use than that though
Henry
Old Jul 5th, 2005, 01:36 AM
United-States That makes more sense, but...
Where are the hydraulic tappets hiding? I could plainly see the rollers against the cam lobes... Maybe my brain fell out my ear while looking! -Jeffy.
Old Jul 5th, 2005, 08:56 AM
Local Time: 06:12 AM
Nearly every OHC engine with rocker arms and hydraulic adjusters hides said adjusters in a machined hole in the rockers above the valvestems. Those "oil seals" you saw are likely the adjusters, which operate under oil pressure from the rocker trunnion.
Old Jul 5th, 2005, 12:49 PM
Cooper_si's Avatar
the DASH LIGHT king ? ;)
Send a message via MSN to Cooper_si
To help Jeffy ive got some pics for you of the head and valves...you can just see the yellow caps above the valve that attaches to the rocker arm on the second pic....
Hope this helps
THE Legend who helps ALL MINI owners
Old Jul 5th, 2005, 01:08 PM
Cooper_si's Avatar
ok...i went one step further i stripped down the head to show you one of the rockers....the tip (where the yellow bush is) has a swivelling ball (to follow the travel of the valve going up and down) inside the tip of the rocker houses a small hydrualic peice that can be pushed up and down etc etc.....hope this answers your question
Old Jul 6th, 2005, 05:41 AM
United-States That was excellent...
A swivelling ball, eh? What if the contact area were made larger- could I get a little more valve lift? Since you've seen the ports in these heads, tell me: are they perfect like in a race engine, or can I gain some power by porting? I never port to just enlarge the tunnel; I just remove aerodynamic disturbances left by mass- produced machining. My results have always been very good, but I did once run into some BMW heads that I couldn't improve- they were very clean. I really appreciate the photos accompanied by explanation. That was excellent! -Jeffy.
Old Jul 6th, 2005, 01:10 PM
Cooper_si's Avatar
Heres a picture of the valve contact surface with relation to the rocker...as you can see its quite precise in measurements so im not sure if increasing the surface area would amount to much.
A bad picture of the exhaust port of the head...MINI heads are renowned to breathe much easier with porting but upon viewing both the exhaust and inlet theyre not to bad really...unless you intend knife edging the ports then thats a different matter
Glad to be of assistance
Old Jul 6th, 2005, 04:15 PM
uae mini's Avatar
Send a message via MSN to uae mini
Local Time: 08:12 PM
United Arab Emirates View uae mini's Dark Silver & Black 1st Gen MINI Cooper S Profile
This is what I call a post that helps... come to think of it, my post doesn't help at all
Cooper S --- Lots of mods all here
Old Jul 6th, 2005, 05:28 PM
Mini2 Sponsor & Tuner
Local Time: 08:12 AM
this might be a better photo [IMG][/IMG]
Old Jul 7th, 2005, 02:46 AM
United-States Those posts should be seen by all who seek more...
That really was some good stuff! I could see some area for improvement in the first exhaust port pictures, then was impressed with the slick port work by Kumho Kid. When people take the time to respond to a post like you guys did, the whole forum and, therefore, the world of Modified Minis is benefited. Thanks for the pics and info. Now I know that I could definately gain some power by pulling the heads for port work. After seeing how the rockers work, I realised that changing the camshaft would be the better choice- provided there are cams available for these, to include non-supercharged cars. Otherwise, I could probably get a custom ground cam from a California shop like Crower. They made me one for my old BMW 2002- for a third as much money as Schrick, who were the race/high perf. cam designers for German fast cars. -Jeffy.
Old Jul 7th, 2005, 01:39 PM
there are major clearance issues with the spark plug guides
even the biggest schrick cam needs you to dent them to clear....
Valve train noise MVW First Generation Faults & Fixes 5 Jan 8th, 2003 04:03 PM
another train ride!!! Gary Tate General Discussion 13 Jul 27th, 2002 01:50 PM
