| Ryephix bypass valve? I'm curious what exactly this does, I wasn't able to come up with much through searching. Is it a good idea considering I have an '02? And is this one in particular a good piece? |
| Yes it would. Also depending on the class your in you can do a complete override for the bypass valve which helps with power but lessens your fuel milage. I currently run in SM class and have made the override and readjusted the Butterfly myself so it does seat all the way. Much like what Ryephix does but i didnt add the better spring since i have the override. Also just by changing to Ryephix valve since it is a stock part just adjusted properly it wont take you out of the stock classes 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| Sorry, but I must disagree with Mugami. The addition of a heavier spring is NOT an allowable mod in SCCA stock class. This would be much the same as doing an internal modification to your engine. Unless the modification is approved by the manufacturer and documented in writing it is not permitted. The only modifications to stock category cars that are allowed are those specifically mentioned in the rules. Tom 02 EB/B MCS |
| Thanks Tom.. Granted im new at Autox and i knew i was in SM before i began. im just also aware of a few in the area running in GS that have the Valve. so i took it as ok. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| well..whenever it is that I do get started, I won't have a stock car, so class will be an issue when it comes time to head out for the first time.. so...all in all, a good idea to buy it if I want the stiffer spring? |
| Bypass valve seems to be leaking????? | Loui | First Generation MINI Tuning | 0 | May 28th, 2007 09:26 PM |
| optimised bypass valve | miniwurks | First Generation MINI Cooper S | 8 | Feb 15th, 2007 09:04 AM |
| Optimise Bypass Valve | MuffinMan | First Generation MINI Tuning | 1 | Nov 22nd, 2006 06:01 PM |
| Bypass valve recalibration | THE ITCH | First Generation MINI Tuning | 33 | Feb 16th, 2006 08:58 PM |
| Eaton bypass valve | FAT MINI | First Generation MINI Tuning | 4 | Oct 4th, 2004 01:01 PM |
