19% reduction Q - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 31st, 2005, 05:30 PM
Southern Florida Coop S'
Local Time: 05:53 PM
19% reduction Q
sup! ill get right to it.
the performance shop wants to add a 700$ re-map to my ECU.. he says that it is horrid for the engine wiht out it
19% reduction 138 (pulley)
200 labour
+700 ECu upgrade.
I don't plan to keep this ccar more than a year (05' cooper S)
Is it true that the car needs a re-mapfor the pulley reduction?
Old Aug 31st, 2005, 07:27 PM
Profpatpending's Avatar
Forum Hardened
preferably with the 19% you should have the 400cc injectors and get an MTH remap for half the price.
Old Aug 31st, 2005, 08:00 PM
MINIAC's Avatar
Canned
Local Time: 10:53 AM
While an ECU remap is required if you add larger injectors along with a 19% pulley, one is NOT required for just the 19% pulley by itself.
Helix offers the GIAC (19% pulley + larger injector) remap for $325.
Old Sep 1st, 2005, 04:04 AM
Ryephile's Avatar
Deals Gap Junkie
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Local Time: 01:53 PM
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile
Speed Density ECU's, which use MAP sensors to calculate air weight, adapt to boost changes automatically. Your performance shop is trying to rip you off by claiming the engine won't run properly without the ECU re-tune. That said, a proper re-tune will improve HP and torque, but it's certainly not a requirement.
If all your changing is the s/c pulley, the stock injectors have enough capacity even in high-IAT fuel-dump mode. No need to change them unless you're pushing over 220cHP.
Cheers,
Ryan
Reduction Pulleys... MiniLover247 First Generation MINI Tuning 2 May 21st, 2006 04:58 AM
Weight reduction ecylai First Generation CVT & Automatic 11 Mar 31st, 2006 05:57 PM
15% reduction and standard SW LordNikon First Generation MINI Tuning 14 Mar 4th, 2005 09:12 PM
Wieght Reduction? PortRhombus First Generation MINI Tuning 13 Nov 7th, 2004 04:29 PM
Price Reduction.... cfranklin General Discussion 2 Dec 18th, 2003 07:37 AM
