pulley upgrade - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 10th, 2005, 03:27 AM
Local Time: 03:53 AM
Australia
Australia pulley upgrade
I have just ordered from the USA an ULTRIK 15% reduction pulley for my 2002 Mini S. How easy are they to fit if you have average mechanical skills rather than paying for a mechanic to do the work? Any clues ?
Old Sep 10th, 2005, 04:15 AM
MiniFr34k's Avatar
fr34king n00b!
Australia Male View MiniFr34k's Classified Ads
hey mate, theres a DIY around here somewhere.. if not have a look at www.webbmotorsports.com , there would probably be one there.
but to answer ur question, it looks pretty complicated, esp if u dont have the pulley removal tool to remove the stock pulley and given that ur meddling with ur engine, u'd probably want this done right
post some pics and let us know how u go with the DIY
Old Sep 10th, 2005, 04:41 AM
XTREEM's Avatar
Local Time: 04:53 AM
Australia
If you have average mechanical skills and Randys instructions, its pretty straight forward, but you do need the pulley clamp.
John.
Old Sep 10th, 2005, 06:30 AM
Australia
Australia
Thank you for the advice it appears from the pages you sent me to that i need a pulley puller and also a belt tensioner tool unless you can obtain the special, standard pulley puller. I think i will take the car to my BMW agents Klosters in Newcastle, get them to do the work.
Old Sep 11th, 2005, 12:44 AM
aceman's Avatar
That Sound Dude
Send a message via MSN to aceman
Australia Male
Hey I just bought my 02 MCS from Klosters, the best service I have ever had from a dealer.
Let me know how the pulley upgrade goes as I would be very interested myself
Old Sep 11th, 2005, 01:31 AM
mike's Avatar
Local Time: 11:53 AM
United States View mike's Electric Blue & White 1st Gen MINI Cooper S Profile
I installed an ALTA pulley myself a year and a half ago. I watched an ALTA rep do 3 jobs in an hour each and charge $400. each job, part included. My skills are good, I refuse to part with that much cash so.....The engine/trans jacking up is frightfull if you have not seen it done. I was able to build a pulley removal tool that worked, it was pretty well destroyed when I was done. Once the old pulley is off, 30 minutes later you are starting the engine. The result of the pulley change is nothing short of awesome, I strongly suggest you consider a new exhaust at the same time. I installed an ALTA exhaust, I was driven by the sound and they had what I wanted. Power comes on in the 2700 range and stops at the rev limiter, and the S snarls all the way up. The wheels spin in 2nd and 3rd with little help. Anyway, I digress. I took about 6 hrs to do the job, mostly removing the old pulley. The space is limited to work in. enjoy
Mike
Semper Fi
MCS, built 29 Mar 02 delivered 17 May 02
73 Mini 1275, 68 BMC MINI tractor
Old Sep 12th, 2005, 12:57 PM
Australia
Australia pulley puller
Thanks for the support Mike. A question about your puller where did you get the dimensions from so that you could manufacture a pulley puller and how did you over come the issue of access did you have to remove the belt tensioner? or did you copy the design showed in the minimania pages?? that allows you to remove the pulley without removing the tensioner?
Old Sep 14th, 2005, 01:13 AM
mike's Avatar
Talking
The puller I built mimiced the bilit type the companies use. They turn theirs on a CNC type machine and clamp it on the pulley. I used steel U shaped clamps and a puller to do it. I destroyed the pulley and puller in the process. The idler is an easy part to remove. The hardest mentally is jacking the motor/trans assembly up after removing the bolts. You must lift it high enough so the supercharger pulley and shaft are above the frame far enough to work on. Factor in that you are working on an expensive bit of machinery...use caution, NO impacts at all on the shaft, just pull force. Other than that, piece of cake!! I am still running my original belt, 33,000 miles and no slippage at all. You might find that some pulley retailers will lend/rent the puller when you buy the pulley. I think this would save a HUGE amount of time and effort.
Good luck
Mike
Semper Fi
Old Sep 14th, 2005, 10:13 AM
Australia
I will let you know how i go minimania in USA posted me my new pulley and belt yesterday so i will have a few weeks to manufactre a pulley clamp before the new parts arrive. What dia did you make the hole on your clamp before you split it ? thanks
Stephen
Old Sep 14th, 2005, 11:31 PM
hyprblu's Avatar
Australia Male
Know this may not help at this stage but I am going for the 17% pulley from Promini which I am getting from Craig at Wheel warehouse in Adelaide. He will loan me the complete installation kit including pulley puller and tensioner bar etc. The loan cost of the kit is just the cost of getting it back to him when I have finished.
Are you replacing your plugs with a cooler version as well?
Old Sep 15th, 2005, 06:43 AM
Australia
Australia
Thanks,do you have a telephone number for Craig at wheel warehouse? If not can anybody help me with the Major and Minor diameters of a standard supercharger pulley alsothe pitch of the belt v's. I will have a go at machining one up my self. Thanks Stephen
Old Sep 15th, 2005, 07:06 AM
hyprblu's Avatar
Australia Male
Craig's number is 08 8295 1033. I think he is o'seas for 2 weeks but there are other guys there. I have the pulley puller set on its way to me at present as I am having mine installed by my BMW dealer next week.
Old Oct 13th, 2005, 01:04 PM
Australia
Well its fitted and what a blast best bang for bucks deal ever.Thanks to all those who sent suggestions. I manufactured a pulley puller but I asked Klosters BMW in Newcastle to fit the 15% Minimania pulley and belt job took 3 hrs. I don't know if I'm dreaming this, but my on-board computer tells me I'm getting 6.8 L/ 100 at 115Km on F3 freeway. As opposed to 7.1 with standard pulley has any body else had this experience? Or is this due to other variables such as temp /humidity etc.
Old Oct 13th, 2005, 02:02 PM
XTREEM's Avatar
Australia
Yeah my economy didnt suffer with the 19% pulley. It was the MTH which killed it.
  #15 (permalink)
Old Oct 19th, 2005, 07:05 PM
Il Generale's Avatar
Local Time: 05:53 PM
Italy
Is good the 19% pulley with the mth tuner file..?
Pulley upgrade without re-map... Worth doing??? jonnyc First Generation MINI Tuning 5 Sep 16th, 2005 10:59 AM
Is it possible to upgrade the pulley even M4Mozart First Generation MINI Tuning 4 Sep 16th, 2005 12:26 AM
is it necessary to upgrade intercooler with 17% pulley? mobile23 First Generation MINI Tuning 32 Jan 1st, 2005 08:10 PM
Cost for pulley upgrade makemineamini First Generation MINI Tuning 4 Jun 5th, 2004 08:15 AM
Supercharger pulley upgrade QQQ First Generation MINI Cooper S 0 Jun 25th, 2002 09:13 AM
