MINI Cooper S with John Cooper Works G_P Tuning Kit - Page 116 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (1) Thread Tools Rating: Thread Rating: 15 votes, 5.00 average.
  #1726 (permalink)
Old Apr 16th, 2006, 05:33 PM
Fabio's Avatar
F43i0
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
Local Time: 12:35 AM
Ireland Male View Fabio's Classified Ads
what about this part
"Modifications to the intercooler as well as engine tuning measures have increased power output of the supercharged 1.6-litre engine on a standard MINI Cooper S JCW by 8bhp"
  #1727 (permalink)
Old Apr 16th, 2006, 05:41 PM
LMB
...where´s the any-key?
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
My understanding was Torque was key figure as it was the amount of power at the wheels. From what I've read both the 210 JCW and GP have the same max torque at the same revs. The rev limit does seem to have been raised slightly, which seems to be where the extra bhp has come from. But I don't understand the benefits.
  #1728 (permalink)
Old Apr 16th, 2006, 05:42 PM
LMB
Quote: Originally Posted by MINIAC
I believe it's what was originally posted for the GP.
Edit ...
MINI USA is showing torque at 184ft-lb (250Nm) but with disclaimer
NOTE: Horsepower figure is "actual" not metric
So it quotes a lower bhp (UK 218) but a higher Torque....wtf??
  #1729 (permalink)
Old Apr 16th, 2006, 05:43 PM
MINIAC's Avatar
Canned
Local Time: 04:35 PM
No difference in horsepower ...
160kW = 214.5HP (US) = 217.5PS (UK)
  #1730 (permalink)
Old Apr 16th, 2006, 05:44 PM
Fabio's Avatar
F43i0
what your saying makes sense and its probaly what we'll get. Benifits i'm unsure of either
but hasnt top speed been quoted at 150mph???
  #1731 (permalink)
Old Apr 16th, 2006, 05:47 PM
Paul's Avatar
MINI2 No.1
England Male
What I don't get is if the Max torque remains at the same Revs as the Works Kit, how is raising the Rev Limit going to help?
OK, it depends on the torque curve, they may have made improvements so the torque doesn't tail off so much so soon.
Here's some calculations for you, going roughly from the 210 curve on the JCW website, then applying guesses at a higher rev to show what BHP it might give you.
If they could improve the torque curve (but not max torque), then you could in theory get better max power, without increasing the max torque.
215 (158.5 lb/ft) x 6950 / 5252 = 209.7
214 (157.8 lb/ft) x 7100 / 5252 = 213.6
213 (157 lb/ft) x 7100 / 5252 = 212.2
219 (161.5 lb/ft) x 7100 / 5252 = 218.3
  #1732 (permalink)
Old Apr 16th, 2006, 05:49 PM
LMB
Yeah 150mph.....maybe the higher revs allow the engine to squeeze a few more mph at the higher revs. So technically it is only the top speed that is quicker? The higher revs give a few more mph in each gear, which shaves a few milliseconds of 0 - 60?
That would make sense.
  #1733 (permalink)
Old Apr 16th, 2006, 08:42 PM
The Red Baron's Avatar
Oh good grief!
United Nations View The Red Baron's Classified Ads
Or not!, according to the small print on the back of the GP brochure.
"The people, quotes and events described in this flyer are enttirely fictitious and any resembalence to actual persons, living or dead is purely coincidental"
Ehh?
  #1734 (permalink)
Old Apr 16th, 2006, 09:00 PM
LMB
Ehh?
That's just general legal crap to cover their backs.
  #1735 (permalink)
Old Apr 16th, 2006, 09:35 PM
Wobert's Avatar
Mr 120d Sport
United Kingdom Male View Wobert's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile View Wobert's Classified Ads
Quote: Originally Posted by Wobert
Your initial comments about raising the rev limit giving the power increase appear to be correct.
I've used the power / torque curves listed on the JCW website for a std MCS with the 210 bhp conversion, and have extrapolated power and torque values across the full speed range.
I've also derived the values using simple equations to check my accuracy of extrapolation.
Bearing in mind the torque curve on a standard JCW MCS falls away fairly gradually, by increasing the peak power speed by 100 rpm gives the final 8 bhp (5.96kW) over and above the std JCW engine.......this will only be done via modifying the ECU programming.
This is the post I originally made about the issue with raising the rev limit by 100 rpm.......
  #1736 (permalink)
Old Apr 16th, 2006, 09:42 PM
LMB
What are the advantages of increasing the range? Allowing greater speed per gear?
  #1737 (permalink)
Old Apr 16th, 2006, 10:47 PM
Wobert's Avatar
Mr 120d Sport
Assuming the gearing stays the same, yes.........
In reality, it's just a cheap way of increasing the headline power figure for minimal effort / technical risk, as all the engine sub-systems will be rated far, in-excess in terms of their speed limits.....so you're not risking durability issues in terms of long term engine longevity.
100-150 rpm is pretty minimal TBH.........and it's easy to implement too, as it would only need an ECU program tweak to achieve.
  #1738 (permalink)
Old Apr 16th, 2006, 10:50 PM
jimskater's Avatar
'til death do us part
Send a message via MSN to jimskater Send a message via Yahoo to jimskater Send a message via Skype™ to jimskater
United States Male View jimskater's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
I think I need a GP brochure.
None available in the US, yet.
www.scmm.org GP 0101
  #1739 (permalink)
Old Apr 16th, 2006, 10:51 PM
LMB
Ok cheers that makes sense.
I guess the weight of the car is going to have a greater impact than the increased bhp.
  #1740 (permalink)
Old Apr 16th, 2006, 10:53 PM
jimskater's Avatar
TBH, I've only ever bumped the rev limiter on the S maybe a dozen times.
I'm just looking forward to the jcw kit, the lsd & the reworked gearbox.
Tags: , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-works/107351-mini-cooper-s-john-cooper-works-g_p-tuning-kit.html
Posted By For Type Date
GPMINI.net Post #0 Refback Nov 26th, 2008 02:09 PM
