GP Brake Life - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 29th, 2007, 11:03 AM
Local Time: 05:59 PM
South Africa
GP Brake Life
Hi All
Was wondering what life you have been getting out of the works brake pads. I have about 5000 miles on the clock and my pads are toast! Is this normal or am I braking to late
Old May 29th, 2007, 11:15 AM
6X therapist
Local Time: 06:59 PM
View Goonery's Classified Ads
Brakes are only for emergencies in my view, maybe you are having too many emergencies
Old May 29th, 2007, 12:12 PM
ALD0's Avatar
Just out of curiosity, are the GP brakes up rated or the Same as a MINI ONE like the Cooper S brakes?!
Old May 29th, 2007, 12:31 PM
alski's Avatar
dyno-mite, might not....
England Male View alski's Classified Ads
aldo, i am sure someone has suggested they are the same as R56?
carefree
Old May 29th, 2007, 12:50 PM
Local Time: 07:59 PM
Kuwait Male View ZZTOP's Classified Ads
This is def. not normal for day to day road use. Maybe if you did a few track days, yes...
But its in S Africa so you have motorplan so brake pad consumption is not an issue , until it expires of course
Old May 29th, 2007, 07:07 PM
6X therapist
The R52/3 Works and GP Front Brakes are basically scavenged from the parts bin of the previous 5 Series Bimmers (not current) and painted red. The R56 versions are basically similar. So a 2001 5 Series up to the change to the latest version will have a set of pads that fit and shoul d last well as the 5er was a much bigger and heavier car and the pads on those lasted pretty well.
Old May 30th, 2007, 03:25 PM
South Africa
Thanks for the comments guys I did notice the BMW logo on the pads and the replacement tip.
And yes it has involved a few track days (only 2 if i recall correctly with limited track time) but i would have expected a bit more from so called uprated brakes.
With regard to the motorplan dealers are quick to decline claims that are outside the normal service intervals, (which is insainely long for this car if you ask me) - under the premise of abuse! As with my Subaru I will have point out that it is talented abuse
Old May 31st, 2007, 10:39 AM
AlexF2003's Avatar
AFRacing
Send a message via MSN to AlexF2003
United Kingdom Male View AlexF2003's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile View AlexF2003's Classified Ads
9k including 3 trackdays and a trip to the ring!
Alex
Alex F - AFRacing LTD
Old May 31st, 2007, 11:27 AM
Blatman
You should book your car in at Midrand for a so called "formula 1" service. You drop it and they put new pads and/or disks in so there is not a specific service time. I have done it a few times with no questions asked.
Which track did you trackday at? I would like to see how the GP shapes around Zwartkops. i am there often and I am the only MINI there....Too many GTI Vs and Focuses (Foci?).
I entered the VW club go-kart challenge there on the weekend, it was one of me vs millions of VW / Audis. I did a quicker time than most of them, only two chipped GTIs were quicker by a few knacker hairs. Proud to say I was faster than an RS4 no less.....
VW Club Go-Kart Track - 27th May 2007
Old Jun 11th, 2007, 03:58 PM
South Africa
ZZTOP thanks for that info will check out Midrand.
I have been to the BigZ once, MIdvaal and the dynamic handling track at Gerotek. Gero was the most fun because the track is so tight but after 3 laps the brakes are smoking badly.
AlexF some of us can only dream of going to the Ring (unless is PS2) .....you luck B#@%$ There are a few of us who ever year threaten to put our cars in a container and send them over so we can go drive the Ring. Maybe one day
Old Jun 11th, 2007, 09:19 PM
AlexF2003's Avatar
AFRacing
But I have been fairly gentle on the brakes as they do fade easy...
Alex
Old Sep 30th, 2008, 09:48 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
I got 30k out of my fronts, which I recently had changed along with the disks
Old Oct 4th, 2008, 03:16 PM
Joogle's Avatar
34k now and only had the front pads changed at around 26k and the rear pads at around 31k. Had the disks checked at the same time and the last service and the garage said they were fine.
Its a very difficult job and the only way to get through it is we all work together as a team.....
Which AFTERMARKET brake pads will be compatible with brake sensors? wrxtomini Maintenance & MINI Care 0 Apr 22nd, 2006 03:17 PM
Brake Pad Life whovous General Discussion 4 Feb 13th, 2005 07:31 AM
Brake pads and brake disks (rotors).. HELP GIII First Generation MINI Cooper S 2 Nov 10th, 2003 07:23 PM
new alloy and tyres will i need to get new brake discs and brake pads TREBALZ Wheels, Tyres & Brakes 7 Sep 23rd, 2003 11:24 PM
