JCW Air Filter Changing Guide For Noobs - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Jul 24th, 2008, 09:39 AM
Space Cadet's Avatar
Local Time: 06:01 PM
I have just ordered an ITG filter, hopefully it is going to arrive tomorrow so I will be able to fit it at the weekend.
Firstly thanks for the guide, very easy to follow, have printed it out and will use it at the weekend.
It seems to be a good mod to disconnect the flap that opens at 4.5k RPM, where exactly is the flap??
Is it the small round hole in the bottom part of the air-box, as in picture 11? Or is it actually in the top part of the air-box, presumably that fits into the large oval’ish sized hole in the firewall also as in picture 11?
Excuse my questions, its just that I haven’t opened her up yet so don’t know the lay-out.
Plus also what’s the consensus of what to do with the flap and/or hose (again don’t know exactly what I’m talking about yet), should I just tie it/them up somewhere so that they still open but just don’t affect the air-box, or should I remove them altogether? (If so what actually should I remove?).
Thanks, Mark
  #17 (permalink)
Old Jul 28th, 2008, 06:57 AM
Fitted the filter and removed the flap at the weekend, can’t say I’ve noticed a huge difference but it’s nice to know it’s in there.
While I was doing it all I looked at removing the bung in the bottom half of the air-box in-between the air-box and the fire-wall. If you take it out the air-box gains another hole to get more air through, like removing the flap.
The only ‘problem’ was there is a small gap between the air-box and fire-wall theoretically letting hot air from the engine bay get in.
I had a closer look at the bung and inside it was a plastic disc, I just popped this out and then was able to replace the bung which sealed the gap between the air-box and fire-wall but because the bung is now not blocked by the disc it will let some more air in.
Bonza.
Also, what peoples' view on removing the ‘motor’ that controls the flap, it seems to take up a lot of room in the air-box that would otherwise allow better air-flow to the filter.
The only problem would be what to do with the end of the vacuum hose that goes into it; would it be safe just to block the end up?
  #18 (permalink)
Old Jul 31st, 2008, 10:45 AM
TimG's Avatar
United Kingdom Male View TimG's Classified Ads
Useful guide, thanks! Just used this myself
  #19 (permalink)
Old Jun 17th, 2009, 07:57 AM
GP 1541
Local Time: 07:01 PM
Really clear and simple to follow guide - thanks!
I struggled a bit getting the hose clamp back on (with pliers!) and wished I'd bothered to go buy a 'normal' clip. Got there in the end by sheer will power
Also gave it a 'flapectomy' while I was in there :-)
.. I kept the flap though and left the vacuum pump etc. in there, just in case I change my mind (like if my fuel consumption increases massively).
Sounds great though
  #20 (permalink)
Old Jul 15th, 2009, 05:57 PM
curenz's Avatar
New Zealand Male
I remember seeing this thread months back, and it's taken me about a week to find it again! Would have sworn I had it book marked. Pushing it back up
Tags: , , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-works/148849-john-cooper-works-air-filter-changing-guide-noobs.html
Posted By For Type Date
MiniSpirit.Com • Vendo Tópico - JCW filter change This thread Refback Mar 4th, 2009 02:44 PM
Changing Air Filter and Plugs Mins21 First Generation MINI Tuning 2 Feb 4th, 2008 06:56 PM
Guide on changing rear brake disks & pads A24MIS Wheels, Tyres & Brakes 2 Aug 31st, 2006 09:59 PM
Changing the Air Filter on a Cooper S Zipperblues First Generation MINI Tuning 6 Apr 11th, 2006 05:33 PM
Changing cabin air filter? Hubert Maintenance & MINI Care 2 Feb 1st, 2005 09:01 AM
Changing the Oil Filter frails Maintenance & MINI Care 0 Jun 22nd, 2002 03:38 PM
