Clutch & flywheel replace - MINI Cooper Forum
post #1 of 6 (permalink) Old Jan 30th, 2014, 10:49 PM Thread Starter
Local Time: 05:33 PM
Hi everyone. I've got a jcw 55 plate 45000 miles. I need to replace clutch & flywheel! Any suggestions and what else should I change along side this? I'm going for a standard system from bmw or should I go pattern parts like LUK? Are these any good and is there any difference in oem Parts & original parts? Thanks Asif
Asif jcw is offline
post #2 of 6 (permalink) Old Jan 31st, 2014, 12:15 AM
mab01uk's Avatar
Local Time: 04:33 PM
Quoted: 1 Post(s)
I personally would use genuine BMW parts if the clutch judders or anything on a pattern part any small cost saving will be lost when the gearbox has to come out again........
While in there it is a good idea to replace the crankshaft rear main oil seal....if it starts leaking later as they sometimes do, it will ruin the new clutch and involve the gearbox coming out again to replace. Also replace the clutch release/thrust bearing as these can become noisy later.
More info here:-
"The next step is to replace the rear main seal. This seal is an important one as it seals the gap between the crankshaft at the engine block. If this seal were to fail, it would start leaking oil all over the ground and likely onto the clutch plate as well, rending your clutch basically useless. This is one of those 'while you're in there' items that really should be replaced."
Pelican Technical Article: MINI Cooper - Clutch Replacement
1320 Optional Related Services
Clutch Kit Supplied & Fitted - R53 £540
"We recommend replacing the rear main oil seal while the gearbox is out and the clutch is off. This seal sits around the crank behind the flywheel and often leaks engine oil over time, sometimes the leaking oil can get onto the clutch plate / cover surface causing premature clutch slip and eventual failure.
We can fit a genuine MINI replacement crankshaft oil seal while the clutch is off for £54
As part of the clutch replacement procedure we have to remove the front sub frame, if your front bushes are worn this is the ideal time to upgrade your wishbone bushes to new Superflex poly urethane bushes saving you £84 over the regular replacement price.
Remove and fit new Superflex front wishbone bushes for £132"
Clutch Kit Supplied & Fitted - R53. MINI - Servicing - Repairs - Tuning - Parts - Spares
mab01uk is offline
post #3 of 6 (permalink) Old Feb 2nd, 2014, 11:33 PM Thread Starter
Hi mate. Thanks for all the info much appreciated. What oil would you recommend for the gearbox as I hear this will be drained upon clutch renewal? Thanks
Asif jcw is offline
post #4 of 6 (permalink) Old Feb 3rd, 2014, 07:40 PM
mab01uk's Avatar
Quoted: 1 Post(s)
I use 2 litres of MTF94 but as you will see in link below there are other options, if in doubt check with a MINI Dealership using your VIN number.
http://www.mini2.com/forum/maintenan...tf-lt-3-a.html
mab01uk is offline
post #5 of 6 (permalink) Old Mar 3rd, 2014, 09:18 PM Thread Starter
thanks. my garage are saying there would be no need to drain the gearbox oil?! also im going for a LUK clutch & flywheel as its much cheaper and im told its really good?
Asif jcw is offline
post #6 of 6 (permalink) Old Mar 3rd, 2014, 11:43 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Gearbox oil change is not essential on the MCS as box is fairly bullet proof.
I have no experience of using the LUK parts.....I would ask somewhere like 1320 for their advice on pattern/aftermarket parts recommended......you don't want to do this job twice.
mab01uk is offline
Looking for feedback on clutch issues ('08 Clubman S) Blue08ClubmanS MINI Clubman 8 Jan 25th, 2014 09:39 AM
Clutch issues - perhaps the slave cylinder nad_84 First Generation Faults & Fixes 3 Dec 1st, 2013 09:28 PM
Clutch bleed Clarification MiniDeLux Second Generation Faults & Fixes 0 Nov 21st, 2013 03:37 PM
Stubborn Dealership over Clutch Bleed MiniDeLux Second Generation Faults & Fixes 0 Mar 18th, 2013 11:45 AM
What RPM do you start 1st with? thewhitenight000 First Generation MINI Cooper 2 Aug 8th, 2012 07:19 AM
