Yoyoing & poor startup - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 29th, 2014, 12:55 PM Thread Starter
Local Time: 09:47 AM
Hello. I've got this kangarooing or yoyoing at high revs and my car occasionally does not start up well! I've replaced the CAT serviced the car and replaced the bypass valve! Please can someone help with this. Many thanks
Asif jcw is offline
post #2 of 3 (permalink) Old Jun 29th, 2014, 02:01 PM
Quoted: 1 Post(s)
Scotland
It sounds to be a fuel system fault, look into your fuel injectors and your fuel pressure reg, it sounds like there is a possible failure in there.
Minitech93 is offline
post #3 of 3 (permalink) Old Jun 29th, 2014, 04:40 PM Thread Starter
Hi. My fuel pressure reg was replaced last year. Injectors have been cleaned with special fluid car still the same. I think my fuel pump makes a constant whining sound now! My black fuel vent valve in the engine bay has recently starting making a ticking noise after the car has been start for screw minutes. Thanks
Asif jcw is offline
