Lamder sensor - MINI Cooper Forum
post #1 of 7 (permalink) Old Jul 8th, 2014, 08:32 PM Thread Starter
Local Time: 05:17 AM
Lamder sensor
Hi guys. My engine management light came on and it's pointing to the lamder sensor is faulty?! I've only a few months ago replaced my O2 sensor pre cat. Are these two the same things? If not where is the lamder sensor? I have a R53 55 plate jcw!? Many thanks. Oh and I have a janspeed manifold & sports cat fitted with ITG airfilter
Asif jcw is offline
post #2 of 7 (permalink) Old Jul 8th, 2014, 11:43 PM
Local Time: 04:17 AM
Hi ya
There are two one pre cat and one post cat and there different part numbers. Normally it's the post cat that puts your light on. Check all your wiring is ok and not damaged and the connectors are clean no corrosion on the pins
I would get it plugged in to a diagnostic machine and check the O2 sensors. I would also get the cat checked, for some reason the minis eat non standard cats as the gas temp is high.
Hope this helps
marque is offline
post #3 of 7 (permalink) Old Jul 9th, 2014, 03:01 AM Thread Starter
Hi. Thanks for your reply. I changed my CAT and manifold for janspeed one recently and an ITG airfilter. Could this be causing it? It's at a garage now they will confirm which sensor it is and replace it. Many thanks
Asif jcw is offline
post #4 of 7 (permalink) Old Jul 9th, 2014, 02:06 PM
Hi ya
Get them to check the O2 sensors, it could be the cat failing it has been know.
Did you reset the ECM after these mods ?
marque is offline
post #5 of 7 (permalink) Old Jul 9th, 2014, 02:31 PM Thread Starter
Hi. What's an ECM?? Thanks
Asif jcw is offline
post #6 of 7 (permalink) Old Jul 9th, 2014, 03:25 PM
Engine control module
Basically the engines brain to reset it you disconnect the battery for 20-39 min neg then poss then to connect poss then neg.
Some times it need reseting it learns the bad habits as you drive it, so sometimes it's best to reset it, but if you do a mod to the engine it best to do a reset anyway then it starts to learn again it normally takes about a tank and a half of fuel to fully learn
marque is offline
post #7 of 7 (permalink) Old Jul 9th, 2014, 11:36 PM Thread Starter
Hi thanks mate I've spoken to the garage and they said yes they reset the ECU through autologic scanner
Asif jcw is offline
Brake wear sensor or not ? UtilityGuy Wheels, Tyres & Brakes 4 Apr 17th, 2014 12:59 PM
Convertible rear sensor replacement k3fus First Generation Faults & Fixes 1 Feb 16th, 2014 05:17 PM
very strange engine issue? genik Second Generation Faults & Fixes 16 Aug 11th, 2013 07:09 PM
OBD Error P2270 - O2 Sensor? m500crt First Generation Faults & Fixes 0 Aug 14th, 2012 07:20 PM
Tire pressure sensor ShadowFax Wheels, Tyres & Brakes 3 Aug 6th, 2012 07:23 PM
