MCS Supercharger vs Works Supercharger - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 1st, 2003, 09:42 PM
LMB
...where´s the any-key?
Local Time: 09:29 PM
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Exclamation MCS Supercharger vs Works Supercharger
Are they the same size?
All the literature I've read on the works kit says that it has a larger supercharger.
Old Jul 1st, 2003, 09:49 PM
Tonyt3's Avatar
Track addict
Local Time: 10:29 PM
Re: MSC Supercharger vs Works Supercharger
Does MSC = MCS?
They are not the same surely. When I spoke to the techs at JCW they said they binned the stock item and replaced it with "the next generation" item. Don't think they would get away with simply binning the stock item because they didn't want to pull off the pulley. If it were the same SC, but just teflon coated, then that would surely be supplied as standard to the factory cars now.
Old Jul 1st, 2003, 10:06 PM
Nic D's Avatar
Wales
Hmmm what i heard was that the only difference was teflon coating Tony. More marketing ******** perhaps?
Old Jul 1st, 2003, 10:10 PM
Tonyt3's Avatar
Track addict
Iteresting term that... Teflon Coated usually means ******** doesn't stick!!!!!
Old Jul 1st, 2003, 10:16 PM
England
@ Tony
This whole JCW supercharger thing is doing my head in. Why can't someone from JC just admit that its £3.5k for a pulley, ECU & exhaust - the head & charger are just window dressing...
OR... give up more info on what makes the 'new' charger & head worth the extra cash?
Old Jul 1st, 2003, 10:20 PM
Nic D's Avatar
Wales
! Should have phrased that better but i hope my point has come across
Old Jul 1st, 2003, 10:23 PM
Nic D's Avatar
Wales
Got some thirdhand info on the difference between a stock vs. a works supercharger-The impellers seemed to be "coated" with a graphite colored film.We both surmised that the coating was either a friction reducing or frictionless coating of some sort.I know that many Formula teams use coatings or metal transforming treatments for this same purpose.The technician could not tell if any more mods had been done on the item.Will let know the outcome of the install from the mechanics standpoint-
From Liam "S"' thread a little further down...
Old Jul 1st, 2003, 10:39 PM
Nic D's Avatar
Wales
I agree with you Max
Old Jul 1st, 2003, 10:48 PM
LMB
We'll I've just watched the online chat with Mike Cooper on Mini.co.uk.
He mentioned nothing about the Supercharger being bigger, all he said was that the blades have an abrasive coating meaning that there's a better seal->more power and a smaller pulley->more power. Looks like it's a myth that the supercharger is larger.
He also said about the cylinder head, that the inlet ports/exhaust ports are CNC machined->7bhp increase.
What's CNC machined?
Old Jul 1st, 2003, 10:49 PM
England
Maybe I should cancel my S order and go get that manic Impreza WRX I test drove yesterday. Costs £20k but at least I won't be kept awake at night worrying about tefal coated widgets & voided warranties
Old Jul 1st, 2003, 10:51 PM
Nic D's Avatar
Wales
Hehehe i'm waiting Max
The other point about the head, it's contracted out to a company in Swindon isn't it? Bet that could be done to the same spec at a cheaper cost too.
I think the coating is to help with heat dispersion too?
Old Jul 1st, 2003, 11:07 PM
M0D's Avatar
M0D
United Kingdom View M0D's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Now I'm having a shock horror moment! Max - what's all this about boring old DS??
Old Jul 1st, 2003, 11:08 PM
Nic D's Avatar
Wales
I dont think i'll bother with that. Mintex 1144 pads for me next and the manifold back exhuast. Might leave it there...might not
Old Jul 1st, 2003, 11:15 PM
M0D's Avatar
M0D
I never had you down as the UTT type Max?
  #15 (permalink)
Old Jul 2nd, 2003, 12:04 AM
LMB
Didn't realise you were a grandad Max....
No wonder you don't give a ****
Dirty Works Supercharger Intrepid First Generation Works 5 Jul 30th, 2004 07:36 PM
MCS Works Supercharger discoloured! Why? jcworking First Generation MINI Cooper S 4 Apr 23rd, 2004 02:02 AM
Is the MCS supercharger always engaged JohnWB General Discussion 5 Nov 24th, 2003 03:30 PM
MCS 'Works' supercharger GTT 280 First Generation Works 37 Nov 7th, 2003 11:10 PM
MCS Supercharger ericg_0059 First Generation MINI Cooper S 1 Oct 9th, 2002 03:40 AM
