No More Brake Dust On My Wheels !!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 22nd, 2002, 08:24 PM
Local Time: 09:57 PM
I've discovered the secret! I don't use brakes any more. I downshift (ususally to 1st for regular 90 degree neighborhood corners), yank the wheel over hard and slam her through the corner. My wheels have never been so clean!
Ken Shapiro
Electric Blue w/ Sport Package...first "S" delivered in Maryland (5/10/02)
I've been everywhere but the electric chair...I've seen everything but the wind.
Old Jul 22nd, 2002, 08:30 PM
indimini's Avatar
Send a message via Skype™ to indimini
Local Time: 04:57 PM
United States View indimini's Cool Blue & Black 1st Gen MINI Cooper S Convertible Profile
No more brake dust
What a wonderful approach. I'm sure the kids will love it too, but not so sure about the wife.
Have you noticed the tire pressure indicator blink momentarily whenever you corner really hard? It's happened to me once or twice. Couldn't possibly be I was taking the turn too hard?
Old Jul 22nd, 2002, 09:03 PM
Re: No more brake dust
You sure that wasn't the traction control or DSC? I make mine blink regularly! I can't imagine it was the tire pressure monitor.
Ken Shapiro
Old Jul 22nd, 2002, 09:10 PM
noahe's Avatar
Send a message via ICQ to noahe
Local Time: 05:57 PM
Canada View noahe's Chili Red & White 1st Gen MINI Cooper S Profile
I've made BOTH blink. If you get the DSC triangle to light enough, then the tire pressure one lights solid for a bit, until you settle down for a bit again.
Chilli Red/White Cooper S, Sport Pack & Sunroof. Delivered June 12th, 2002!
Now with MCS Winter Tire Package.
Old Jul 22nd, 2002, 10:22 PM
Garfield's Avatar
Ahh, neither of my lights blink. I think my Tire Pressure warning has been broke since I got it (thank god) and I always turn my ASC off unless it's raining.
Back to the braking. Because I heel/toe every single slow turn, traffic light, or stop, I get the same effect. Interestingly, 45,000 miles of driving and autocrossing since new never yielded a brake pad change on my Miata.
The nice thing about the MINI's is that they can so easily be put into first gear. In hard/fast driving, I'm heel/toeing the Cooper S into 1st gear at about 35mph. My Miata had to be doing about 10mph for it to easily go into 1st.
Another way to "eliminate" the brake dust is to run a wheel with less surface area for the dust to land on...
- 2005 G Stock '05 MINI or it's back to a Miata in C Stock
- 2004 G Stock 2nd place Pro Solo, 9th Place Solo II
- 2003 STX 5th place Pro Solo, 6th Place Solo II
- 2002 H Stock Pro Solo National Champion
Old Jul 23rd, 2002, 07:18 AM
HarryHBMCC's Avatar
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Arrow
The low pressure warning uses differential rotation times so in hard cornering you could probably get it to think they were rotating at different speeds not because you are cornering, but because they are flat. That's one of the limitations of an ABS-based pressure monitor.
The ASC+T light goes off all the time on my car but I've never noticed the flat tire light. That said, my eyes are usually on the road and the tach (where the traction warning light lives) for corners, not the speedometer where the flat indicator is, at least for Canadian Coopers.
The ASC+T light is supposed to be a "you're going too fast, slow down" indicator but I usually take that to mean I'm going just fast enough. If I take 'em fast enough that it actually has to kill the engine and/or the tires actually slide, then I know I'm going too fast... In spirited driving on dry pavement I find it is smoother (no brakes applied or engine retarding) to turn it off but if there is ANY water on the road at all then I leave it on as it is very easy to go around a blind corner and find a big puddle. So far I'm quite impressed with how well the ASC can haul in a wet corner. I should probably back off my driving some but it is so much fun and the car feels so glued to the roads that it is hard to take the "ASC+T can't break the laws of physics" advice!
Back to the posted topic, engine braking does work but with those nice big brakes, I like to heel and toe to use both engine and wheel brakes. After 4500km the brake dust has finally started to slow down on my car. Now I can tell too when I've braked hard; there will be an obvious irregular deposit while normal braking just leaves a light dusting
Harry
Old Jul 23rd, 2002, 08:42 AM
iaa's Avatar
iaa
Local Time: 10:57 PM
England View iaa's Chili Red & Body Color 1st Gen MINI One Profile
Up to you, but brake pads are relatively low cost items and cheap to replace, whereas clutch and transmission are very expensive!!
Ian
Old Jul 23rd, 2002, 09:56 AM
Garfield's Avatar
Ian
Well, again, take a look at the mileage I had on the Miata, and that 6-speed was not Mazda's and was not supposed to be very sturdy. Obviously I wasn't too hard on it. Besides, I'm not making the transmission and clutch do anything any different than upshifting...
If you're matching rev's, I don't see what difference it makes.
Not to mention, they're "supposedly" using quite the tranny/diff fluid in these cars. I insisted on putting in Redline and they said the stuff's just as good. We shall see.
Old Jul 23rd, 2002, 02:05 PM
noahe's Avatar
On my car, when the Tire Defect light comes on, the DSC warning light goes on solid too... Probably for this very reason.
The ASC+T light is supposed to be a "you're going too fast, slow down" indicator but I usually take that to mean I'm going just fast enough.[/b]
As much as the ASC+T light comes on during acceleration, the DSC light comes on too, plus around corners, while braking, etc...
Of course driving style plays a part. The missus has never lit the light.
Old Jul 23rd, 2002, 02:11 PM
HarryHBMCC's Avatar
Arrow
The ASC+T light comes on for cornering and hard downshifts/engine braking too but I've never seen it just for wheel braking.
I don't think she'll ever see it while cornering but my wife is sometimes worried about rolling backward on hills and in such cases she'll often do an unintentional clutch dump which activates the light nicely
Harry
Old Jul 24th, 2002, 07:36 AM
indimini's Avatar
Blinking lights
My bad. It is the DSC light that blinks. Had to go out this morning and make sure .
Funny, I thought I had the MINI's features memorized. Guess I need to refresh myself on all the lights in the tach/speedo consoles.
Brake Dust dougwc Wheels, Tyres & Brakes 8 Oct 30th, 2006 11:12 PM
Looking to track # of owners with brake dust pits on wheels schnabeljs Wheels, Tyres & Brakes 7 Mar 8th, 2006 10:53 AM
Brake dust Dirt on my CHROME wheels!!! aVjai Maintenance & MINI Care 9 Jun 5th, 2004 12:41 AM
Help on removing cooked brake dust from wheels rei00 Maintenance & MINI Care 9 May 27th, 2003 07:51 AM
Brake Dust Sausagefingers Wheels, Tyres & Brakes 20 Nov 15th, 2002 12:11 PM
