| View Poll Results: Engine fan problems? | |||
| Has happened | | 13 | 81.25% |
| Heard of it happening | | 3 | 18.75% |
| Idea what it could be | | 0 | 0% |
| Voters: 16. You may not vote on this poll | |||
| Hasn't happened to me, but I've heard of it. I think there's a thread on here about it, but if I remember rightly the most common cause is a stuck fan relay. In very hot weather I've had the fan come on after I shut the engine down but after a few minutes, 5 or 10 at the most, it shuts down. I think it's designed to come on when the engine compartment reaches a certain temp, but it's supposed to shut off again. Hope this helps A car, A legend, A way of life |
| I've had the cooling fan stay on when the car was off, thought not for as long a duration as you mentioned. I haven't checked the radiator coolant level (not just the expansion bottle) though I saw this suggested on another thread (look under 'faults & fixes'). I have a 2003 Cooper. ![]() |
| well yo've got a thermostat ; coolant temp sensor of some kind probably; a relay maybe. pull the plug to fan (still running?) no? o.k. pull the relay . etc. till you locate the culprit. |
| I have an '03 Cooper S and on after a two hour drive in 92 degree heat the fan stayed on for the first time ever. I was so surprised that I popped the bonnet to have a look. I thought something was wrong! I can't say how long it stayed on because I was away from the car for the next eight hours... |
| Last month - when it was very hot over here (compared to usual) - my cooling fan refused to turn off. It ran for over an hour without the engine running and bonnet open, in the end I disconnected the battery, hoping to reset everything. Reconnected it, still running. Disconnected and left over night, everything was back to normal and not had a problem since. |
| (MCS) Problem: Engine Fan Stays On | David_MCS | First Generation Faults & Fixes | 28 | Apr 9th, 2012 10:36 AM |
| power steering pump cooling fan stays on... Why? | 1rabbit | First Generation Faults & Fixes | 7 | Nov 16th, 2006 04:53 PM |
| Engine cooling fan when AC is on | Grimbo | First Generation Faults & Fixes | 10 | Aug 17th, 2006 09:19 AM |
| Cooling Engine Fan Not WOrking | eekthemeek | First Generation Faults & Fixes | 5 | Aug 23rd, 2005 08:01 PM |
| Engine Cooling Fan | Jeffrey | First Generation Faults & Fixes | 4 | Nov 25th, 2004 12:59 AM |
