Price of a replacement ignition key - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 31st, 2006, 06:38 PM
_john_'s Avatar
Local Time: 03:45 PM
Right, my dozy girlfriend has managed to lose her key for the MINI
Does anyone have any experience of getting a replacement ordered, does it take long? I assume they need the car to program the new key to it. Also how much is it likely to cost HER?
Old Aug 31st, 2006, 06:54 PM
Minnie Mouse's Avatar
totally sure!
Local Time: 04:45 PM
England Female View Minnie Mouse's Royal Grey & Silver 1st Gen MINI Cooper Profile
I think your g/f will be looking at around £50 upwards depending where in the country you are!
My dealership in Watford quote £80 per replacement key!
Old Aug 31st, 2006, 08:48 PM
_john_'s Avatar
That's not too bad then, I was expecting at least £100
Old Aug 31st, 2006, 09:45 PM
United Kingdom Male View robby71's Classified Ads
i was quoted around £80 for a remote key and some1 on here posted a couple of days ago he got a non remote key for around £17
you need to go to your dealer with your V5 (logbook) and proof of ID - when ordered it takes a couple of days as the key comes pre cut + programmed to your car
Old Aug 31st, 2006, 11:11 PM
_john_'s Avatar
Thanks for the replies
I've found this thread with more info.
http://www.mini2.com/forum/general-d...lost-help.html
Old Jan 1st, 2012, 11:54 PM
hi just read that you got a new key for your mini... I'm from st albans so i got to go to the same mini branch in watford... Just wondering if you can help me because i also lost my keys & i wanted to know that if your car had central locking and the key you bought was it the remote key the locks with the button & if it was did you just buy that for £80 and it worked staight way because i don't want to spenp loads of money getting the car towed there to get it coded and stuff like that
thanks
Old Jan 2nd, 2012, 08:49 AM
mab01uk's Avatar
Gen 1/Mk1 Mini remote key will be about £100-150 today for the remote key and about £50 for a non-remote spare. The 1st Gen remote needs programming to the car which adds a min. half hour labour charge. You need your V5 reg document to prove ownership at Mini dealer before they will order in key from BMW.
However 2nd Gen/Mk2 Mini remote key is ordered for the specific car (to chassis number) so the code will be stored on BMW's system, the remote will have the code programmed before it is dispached to the dealers, just like the key part is pre-cut to the car before the dealer gets it
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Key not turning in ignition MarkW19 First Generation Faults & Fixes 23 Feb 7th, 2007 03:29 PM
Buzz just before Ignition, on key setting two depudydorg First Generation Faults & Fixes 1 Nov 20th, 2005 10:38 PM
acoustic ignition key warning on/off minicooperdc First Generation Faults & Fixes 4 May 7th, 2003 07:50 AM
Ignition key in position 2? jonesl General Discussion 11 Jan 25th, 2003 06:28 AM
ignition key jammed! IDONEY First Generation Faults & Fixes 3 Aug 20th, 2002 11:26 AM
