Visit Mini Mania UK
Tags: , , ,
Old Sep 30th, 2006, 02:36 PM   #1
burns863
The Muffin Man
burns863's Avatar
Local Time: 02:06 AM
Send a message via MSN to burns863 Send a message via Skype™ to burns863
Service/Oil change reset tool
eBay.co.uk: New OBD 2 II SERVICE / OIL RESET TOOL BMW MINI ROVER 75 (item 160035275723 end time 30-Sep-06 14:39:43 BST)
Am I right in thinking that this tool will reset the information on the odometer about my servicing? I bought my 02 MC second hand and next service due is an oil change. Not got TLC as I never renewed it after the 50,000 miles was up, so I am looking at taking it to a very highly trusted garage for its oil change or even doing it myself. Is it likely that a garage will be able to reset the odometer theirselves or will it be left to me? Hence why I am wondering if this tool is worth it! Also, I dont know if it resets the brake fluid change information.
Hope somebody can help
Old Sep 30th, 2006, 02:39 PM   #2 (permalink)
KPKalle
Knight of the Round Table
KPKalle's Avatar
They didn't use any tool when they changed mine. All done via the onboard computer.
Global Moderator
England Male View KPKalle's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Sep 30th, 2006, 03:21 PM   #3 (permalink)
burns863
The Muffin Man
burns863's Avatar
thanks for the reply! Was your serviced at MINI though? or by a local garage?
Old Sep 30th, 2006, 03:39 PM   #4 (permalink)
KPKalle
KPKalle's Avatar
It was done by MINI.
Global Moderator
Old Sep 30th, 2006, 04:01 PM   #5 (permalink)
philipbklee
Local Time: 10:06 AM
HI, the resetting is done on the speedometer trip rest button by a series of pressing sequence. I think buying the Haynes code 4273 " MINI JUly 2001 to 2005 Owners Workshop Manual is a better choice as it tells you alot DIY stuff than just reseting the service interval.
Its in pg 1.7 to 1.8.
I did mine this way.
Good luck.
Singapore   Reply With Quote
Old Sep 30th, 2006, 07:16 PM   #6 (permalink)
S33BBY
This FAQ should shed some light.
JCW Sound Kit | H/K | Sat Nav | SS+ | Xenons | 17" Anthracite R90s | Goodyear Eagle F1 GS-D3s | ...
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 2nd, 2006, 01:41 PM   #7 (permalink)
Malin Dixon
Malin Dixon's Avatar
The Rover 75 service indicators can be reset by shorting one of the OBD pins to ground. I can't remember the details but I'll look them up if anyone wants them.
I would guess the MINI is the same, and that the tool on Ebay just does that. You can get the Rover 75 info on disk from Ebay for a few quid., and that has how to do it.
United Kingdom View Malin Dixon's British Racing Green & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old Oct 3rd, 2006, 11:19 AM   #8 (permalink)
SamHarrison
Javelin Sam
SamHarrison's Avatar
Local Time: 03:06 AM
Send a message via MSN to SamHarrison
that faq is great.. just printed it off and will be sorting that out on mine tonight...
England Male View SamHarrison's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 3rd, 2006, 12:29 PM   #9 (permalink)
burns863
The Muffin Man
burns863's Avatar
cheers for the replies guys, I will make sure I give that a good read for when my service comes around in a few thousand miles
Old Oct 3rd, 2006, 09:18 PM   #10 (permalink)
Graemewiles
oil/service/pad lights
I fitted new pads to a mini 1 deisel about a month ago. resetted the light by holding the trip button down and turning ignition on but still holing the button do it will send the speedo into reset mode!!!!!!
Hope it works
Solution To Reset The Oil Change minisal Maintenance & MINI Care 17 Aug 31st, 2008 12:24 PM
Is there a service reset tool that resets airbag lights too. Root Ginger Faults & Fixes 8 Jun 29th, 2006 10:03 AM
reset oil service interval - faq method not working kplo Maintenance & MINI Care 0 Dec 18th, 2004 09:04 AM
Exact Tool List for Brake Pad & Engine Oil Change? L8APEKS Maintenance & MINI Care 7 Jan 18th, 2003 04:54 AM
Exact Tool List for Brake Pad & Engine Oil Change? L8APEKS Maintenance & MINI Care 0 Jan 16th, 2003 03:14 PM
