Old Jan 9th, 2007, 09:15 AM   #1
izeko
Local Time: 02:01 AM
Help, Flashing light on dash
Hi,
While driving to work this morning, i suddenly heard a beep from the dashboard followed by the yellow (!) light flashing on the right of the speedo display. When i got to work i turned the engine off and back on again, and its still flashing along with a red (!) on the left hand side which is on all the time.
Any ideas, as i have left the owners manual at home.
Dave
Old Jan 9th, 2007, 09:25 AM   #2 (permalink)
Will_'S'
Stealth Cooper
Will_'S''s Avatar
Local Time: 03:01 AM
Thinks its low tyre pressure if the symbol matches the one on the button at the side of the handbrake then it is. Press and hold button until light resets itself but check your tyres.
Old Jan 9th, 2007, 09:28 AM   #3 (permalink)
izeko
Can you tell me what the tire preasure should be for a standard coopers S on 17" rims.
Dave
Old Jan 9th, 2007, 09:30 AM   #4 (permalink)
Will_'S'
Stealth Cooper
Will_'S''s Avatar
Dave
think it's 30psi approx but there's a sticker on the door cills telling you exactly what it is
Old Jan 9th, 2007, 04:44 PM   #5 (permalink)
Gaz-24
Gaz-24's Avatar
I had the same problem last week, one of my run flats kept going flat after a few days got it sorted now though, mine said to inflate to 32psi on all corners,
once you have inflated them all to the correct pressure turn the key so your ignition lights come on but dont start the engine, hold the button under the handbrake down until the light comes on and stays on, then start the car, this will reset it back to normal, after a few seconds the light should go out.
Hope this helps.
Gaz..........
Old Jan 9th, 2007, 04:46 PM   #6 (permalink)
*Vikki*
Winner MM best MINI ONE!
*Vikki*'s Avatar
yea i have had this before, sometimes happens if i wheel skid to, or when i had a puncure
Old Jan 9th, 2007, 05:58 PM   #7 (permalink)
IH1
I Love My MINI!
IH1's Avatar
I had this last week. I had to replace a tyre and the light came on when driving home. I checked all tyre pressures and then reset the pressure. It did worry me as thhat was the first time it has happened to me so I thought I had been given a faulty tyre!
England Female View IH1's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
AC Light Flashing Jordan210 Interior & Ice 4 Apr 13th, 2007 11:33 PM
Flashing AC Light yellowminijim Faults & Fixes 11 Feb 4th, 2005 05:11 AM
Flashing A/C light?? Silvercooper Faults & Fixes 8 Jan 28th, 2004 10:39 PM
Flashing Orange Dash Light jaimz Faults & Fixes 12 Nov 3rd, 2003 08:08 AM
Flashing interior light and headlamp flashing like a police car angrybeats Faults & Fixes 2 Mar 29th, 2002 03:59 AM
