General DiscussionUse this forum to discuss MINI topics which are not related to other forums. Posts may be moved from here to alternative forums by the moderators without notice
That's interesting! I use V-Power all the time, but the odd times when I can't find a Shell petrol station, I generally have to use 95 RON. When this happens, the fuel economy is shocking, and performance is no where near what the V-Power can provide.
Ah I see. Rare as ... my Cooper Works. Only ever seen one other 132BHP model on the road. Always wondered how many 132BHP kits they did. I know it wasn't long after it came out that BMW watered it down to the 122BHP version
Since switching to 97 and 99 ron fuels I will never go back to 95 unless I have to drive an old car. My fuel economy is so much better with the better fuels!
I didnt even know they did a 132BHP Cooper JCW Kit I wouldnt be able to tell if I had even seen one!
Interesting you would go to all that trouble. Measuring Octane used or fuel brands for economy or performance is over simplified since its only one side of the two essential elements. Air verses fuel mix.
On the air side, ambiant air temperature as well as oxygen content (less in higher elevations) is also a factor. Simply driving the same route with the exact same fuel in a +2 celcius morning and measuring it against the same drive in a +15 celcius afternoon will measurably affect both your cars performance and fuel economy.
It is basically a Cooper Challenge car without the challenge safety equipment.
They can be told apart from the 122BHP version by the exhaust. BMW deemed the car too loud to be approved as it was right on the 98dB limit (there's a gentlemans agreement that cars wont be above 98dB with a lot of manufacturers). They made JCW change the exhaust and in the process lost a load of power. I've never found out if there were ECU tweaks to reduce the power as well.
Incidently the exhaust that was too loud found it's way into the JCW sound kit!
My car produced just shy of 141BHP on a rolling road day too on Optimax.
Oh and yes, I did need a new gearbox! Under warranty luckily!
Very interesting. Firstly though, it was no trouble With the mileage I do I fill up often, I merely just filled up on the same fuel for a periodof time, and then changed for another period of time
Anyways...I had no idea this had any impact on fuel economy? I understood that on a cold morning that more petrol maybe used for the cold start? But after the engine had warmed I didnt realise the air temp was any sort of factor?
When was the version you had out? Will have to look out for one Although to be honest, i hardly ever see any Coopers Works, never mind which version! There anyone else on M2 that has one?
I have acheived 360 from mine on Tesco 97 But my usual mileage is around what you recorded. I suppose it also depends on what we class as "using a full tank"? The mileages I have recorded you see have been untill the red light comes on, but i believe there is around another 8 litres still in at this point so really there are loads more miles to be gotten out of the tank
