| For it to work you need to start off with a full tank, record mileage, drive until you need to fill up again, record mileage and fill tank to full again and keep note of number of litres (or gallons) used to fill up. If you only put £25 of petrol in I'm guessing you didn't put a full tank in (if you're driving a mini that is). |
| Hi Dan, The figures the spreadsheet is churning out are correct. Distance travelled 310, and 25.28 litres of fuel is (25.28/4.55 = 5.55 gallons approx). So 310/5.55 = 55.8 MPG. I think the problem is with the amount of fuel you put in as stated above, or more likely the start mileage. The car needs to be full when you record the start mileage, I'm guessing yours wasn't. Delete your start mileage (75030) and put your end mileage (75340) in cell B4 instead. When you fill up again and record the end mileage the results should make sense. The sheet only works if you are filling the car up to full (let the pump cut out, but don't "fill to brim"). You can use £5 of fuel and refill to full, no problem. What it won't let you do is use £20 and top up with £5, this will give misleading results. |
| I wondered if this was the case! The car was full on the start mileage. But when I filled up again I didnt fill up, I just put 25 in, so this will be the problem. i would normally fill up, but due to money issues i didnt. I will start the sheet again once I fill up next week for work ![]() Cheers! ![]() |
| Tags: economy, fuel, petrol, shell, super, unleaded, v power |
| Fuel Economy?? | Silverstone | General Discussion | 181 | Nov 27th, 2007 02:53 AM |
| Fuel Economy | scottybhoy | First Generation MINI Cooper S | 19 | Sep 24th, 2004 04:34 PM |
| Fuel Economy | ross-s | Maintenance & MINI Care | 74 | May 4th, 2004 01:06 PM |
| help ( fuel economy ) | Richy | General Discussion | 26 | Jun 9th, 2003 07:55 PM |
| Fuel Economy | Leadfootlen | First Generation MINI Cooper S | 5 | Apr 4th, 2003 03:55 AM |
