» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > All Models & Variants > General Discussion
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Jun 18th, 2007, 08:37 AM
Paul's Avatar
Paul
Trained Monkey
Local Time: 01:46 AM
England Male
1st Gen Cooper S Out-Performs 2nd Gen....
Well, compared to their stated figures, according to a Swedish company....
MINI Performs Better Than it Should, Most Cars Dont.
Strange that, as we've seen so many posts on here claiming that the turbo S is well over-performing?
Old Jun 18th, 2007, 09:07 AM
Tigger, Eeyore & Roo's Avatar
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile
Those results are fascinating! It's interesting to overlay the graphs from the supercharged and turbocharged S's and then switch between them!
The supercharged car is up a little on BHP, but it doesn't have that lovely flat torque curve of the turbo and it needs to be revved just a little harder to achieve similar BHP in the mid range. Interesting lack of significant flat spots for either car.
Tigger.
Old Jun 18th, 2007, 09:11 AM
Paul's Avatar
Paul
Trained Monkey
England Male
I certainly thought it was interesting.
Old Jun 18th, 2007, 09:13 AM
ru81
Is there much difference in the weights of the two cars (R53 and R56)??
Old Jun 18th, 2007, 09:39 AM
minicabrio's Avatar
minicabrio
Soon to be deleted !!
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
1st Gen = Unladen weight (EU): 1215 kg
2nd Gen = Unladen weight (EU): 1205 kg
That's for the Cooper S
Old Jun 18th, 2007, 10:20 AM
Japper's Avatar
Japper
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile
The R56 wasn't 'Run in' yet though ( less than 1k ) whereas the R53 was at 11k.
57 Plate R56 PW/B MCS JCW Tuning Kit, Black R105's custom polished black, JCW Carbon fibre, JCW Recaro leather seats, Forge boost tube, Miltek DP, Factory JCW airbox & inlet pipe. Alta Panel filter, NM Eng engine mount. JCW Rear ARB
Old Jun 18th, 2007, 11:41 AM
Tonyt3's Avatar
Tonyt3
Track addict
Hmmm, interesting. They seem to put forward that they are illiminating many of the external factors the Rolling Roads suffer from by taking away the Wheel/Roller interface - however, they must still be doing some 'drive train losses' calculations. BHP quoted by the manufacturer is the true power of the engine, before it enters the many various devices used to put that power down on the road - the gear box, drivshafts, hubs, wheels, tyres etc. These outputs are commonly reffered to as the 'bench' output, the engine quite literally strapped to a bench and tested rather than being installed in a car.
I wonder how many examples they test before they publish a 'base' figure? Ideally, these guys should test 10 'identical' Mini's, then publish the average perfiormane figure, and compare that to the manufacturers claim.....
All of us that have driven more than one of the same car know that they have different powers. Myself and my wife bought near identical Cooper S's at about the same time. Yet her car always felt 10% more powerful than mine - and was faster even though had heavier options.
Old Jun 18th, 2007, 12:15 PM
Paul's Avatar
Paul
Trained Monkey
England Male
It only sounds as if they test one car, a press car, for each type. Also, the fact that Audi's with their four wheel drive system apparently "under perform" very badly (among the worst of all against quoted figures), did make me wonder how they're calculations work in these instances.
Old Jun 19th, 2007, 12:05 AM
OttoMannS
View OttoMannS's Dark Silver & Black 1st Gen MINI Cooper S Profile
If you post this over at R56 "loving" sites such as MotoringFile and NAM, you will get quite the response....
100% Free of French parts
Old Jun 19th, 2007, 12:10 AM
kriation's Avatar
kriation
The Roaming Gnome
Local Time: 09:46 PM
Send a message via ICQ to kriation Send a message via AIM to kriation
United States Male View kriation's Dark Silver & Black 1st Gen MINI Cooper S Profile
As an Audi owner, I can attest to the fact that on a dyno, the Audi seems as if it's under-performing because of significant power losses through the drivetrain. However, at the crank, some of these cars do actually over-perform from the manufacturer's stated numbers.
It's very hard for auto manufacturers to cookie cutter their cars, especially those of the sport/performance category so that they all perform the same. There's quite a bit of variation from car to car because of calculated tolerances during the engineering process.
Talar: 2001 Audi S4 (Stock... ok... maybe not)
Soffi: 2005 DS/B MCS (Stock... for now...)
Old Jun 19th, 2007, 11:51 AM
MINI-Morgan's Avatar
MINI-Morgan
MINI Obsessed...
United Kingdom Male View MINI-Morgan's Solid Black & White 1st Gen MINI Cooper S Profile
Very interesting graphs indeed! I would still like to see an R56 that has been run in on there instead with 5000miles. All good fun! Very nice torque curve on the R56 but very much impressed that the facelift MCS exceeded the manufacture spec.
Old Jun 19th, 2007, 12:41 PM
Paul's Avatar
Paul
Trained Monkey
England Male
It's ALL about the torque in the new S, the engine is a real cracker.
Old Jun 19th, 2007, 01:22 PM
Richard Crofts's Avatar
Richard Crofts
THE STICK
United Kingdom Male View Richard Crofts's Dark Silver & Black 1st Gen MINI Cooper S Profile
I heard it was a real rattler
>>>>>>>Runs for cover
Old Jun 19th, 2007, 01:27 PM
Ant FR
trouble is not many R56's make it past 1000 miles before they go bang.......
  #15 (permalink)
Old Jun 19th, 2007, 01:37 PM
Paul's Avatar
Paul
Trained Monkey
England Male
To be honest, while we had several reports of 1st gen MINIs going up in smoke (literally), and of course the early sparking fuel filler risk (!), I've yet to see that happen to a 2nd gen MINI. But that's beside the point, as this is really about engine tuning/claims against reality than it is anything to do with reliability.
Tags: , , ,
Will 1st gen wheels fit 2nd gen? South Shore Lad Wheels, Tyres & Brakes 9 Jun 14th, 2008 08:35 PM
1st gen wheels on a 2nd gen car? bigpoppa81 Wheels, Tyres & Brakes 3 Aug 9th, 2007 10:26 AM
2nd gen run flats on 1st gen wheels MINIAC Wheels, Tyres & Brakes 3 Feb 11th, 2007 02:48 PM
Armrest: 2nd Gen versus 1st Gen MINIAC Second Generation Interior & Ice 4 Dec 6th, 2006 09:44 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
