Heated Front Screen Upgrade - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 15th, 2007, 08:49 PM
Local Time: 10:48 PM
United-Kingdom Heated Front Screen Upgrade
Hi
Has anyone tried to upgrade their mini by fitting a heated front screen (which is part of the visabily pack) . If so how successful have you been and what tips and tricks can you pass on.
I have done my research and worked out what wiring is needed and the parts i need to buy, but i am not sure if the General Module Control Unit that controls this function will have to be programed to enable this function?
Can anyone shed some light on the subject?
Many thanks
Tony
Old Aug 15th, 2007, 10:31 PM
minicabrio's Avatar
Soon to be deleted !!
Local Time: 09:48 PM
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Hi Tony, welcome to MINI2 ....
This would certainly be one of those items that if not factory fitted surely would not be worth the hassle
Not only would you have to get the correct wiring, but you'd also need a new heater control panel with a button to activate the screen, plus then you'd need the screen itself.
I can't realistically see it as being worthwhile I'm afraid... I do have it fitted (as part of the vis pack) on my car though, and it's mightily effective).
Jon
Old Aug 16th, 2007, 04:37 PM
Hi
I have been used to Fords for the last 5 years and the heated screen in these is truly worth it in my opinion. With a bit of searching the breakers yards, im confidant i will find a control panel and my screen needs replacing under insurance anyway as it has a crack it in.
I up for a challange and i think it can be done with not too much hassle. I just need to know if the GEM module needs programming.
I have all the wiring diagrams for the car and it is not that complicated. My first job this weekend it to track down the wiring to see if it is already fitted to the car.
Old Aug 17th, 2007, 09:33 AM
Jonesy's Avatar
May the Mini be with you!
United Kingdom View Jonesy's Solid Black & Body Color 1st Gen MINI Cooper S Profile
It is a great little option but I must admit, I have only used it twice in the two and a half years!!
Old Aug 18th, 2007, 08:26 AM
LizzyG's Avatar
United Kingdom Female View LizzyG's Chili Red & White 2nd Gen MINI Cooper Profile
I had a Fiesta ST over last winter, and I used the heated screen once, I put that down to global warming
Old Aug 18th, 2007, 08:41 AM
zyo's Avatar
zyo
owt else is just traffic
I've only had to use mine on about three occasions when it was iced up but I've used it quite a lot for demisting the screen and it's great for that.
Tags: , ,
heated front screen adamos o3,cooper s First Generation MINI Cooper S 1 Aug 15th, 2007 10:18 AM
TomTom & heated front screen nat Second Generation Interior & Ice 6 Dec 29th, 2006 08:12 PM
Heated front screen pilgrim509 First Generation MINI Exterior 1 Nov 26th, 2006 07:13 PM
Heated Front Screen Question DCM First Generation Interior & Ice 5 Sep 23rd, 2004 12:06 AM
Heated front screen not working MICKEY First Generation Faults & Fixes 4 Oct 22nd, 2003 09:46 PM
