Mini Pirate
Tags: , , , , ,
Old Sep 6th, 2007, 08:48 AM   #1
Cobby Park Lane
Mini Convert....
Cobby Park Lane's Avatar
Local Time: 03:30 AM
Problems with PL...Scrogg?
Hi guys.
Well ive tried e-mailing mini customer service....but got no response! Ive got my mini booked in to try and fix a whole load of 'little' problems. But i have a fealing they are going to argue that there not waranty issues.....can anyone shed some light on any of them for me?
Ive tried searching, but with no luck!
The list....
Door window seals – causing stripy front windows
Exhaust Rattle
Diagnosed by Stapleton's when doing tyres as exhaust trim being loose, please look at. (Dealer fitted accessory) Seems to have stopped, please look at anyway. Is still loose.
Fix centre of dash
not correctly re-assembled after speedo was removed. Now has gaps, intermittent rattles and two screw holes in it.
whine” from drive belt end of engine.
attempted fix last time, please look at again.
'Whistle' or ''fast tick” from drivers side foot well area.
Noise obvious from inside car when cruising on motorway etc. Only evident from 50mph+ but stops when clutch is dipped. Returns when clutch is released. Noise seem to relate to engine speed rather than road speed. Suspected gearbox whine?
rattle” from drivers door
sounds like its around the door handle area. More evident on bumpy roads, possibly something loose within the door?
rattle” / “buzz” from low on passenger door
Buzz seems to emanate from around the main speaker ring at the bottom of the door. If the door trim and speaker ring are held firm the buzz stops. Buzz only caused when music is on, at reasonably high volume.
Air-conditioning
1) When air conditioning is used, makes a very odd 'hissing' noise from passenger side, behind glove box. Never used to do this. Very annoying noise!
2) Seems to cause a 'whining' noise from engine, and causes it to 'stumble' when progressing through the revs. Noise most obvious as revs get higher, while 'stumbling' most obvious at lower revs. (Will demo to engineer)
3) Smells shortly after AC is switched off. This was looked at on 'inspection 1' but has returned again already.
Front indicator side repeaters
Seem to leek, there is a green sludge built up in the bottom and looks ugly on a car this new. Please change under warranty.
Thanks guys
Neil
United Kingdom Male View Cobby Park Lane's Royal Grey & Silver 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 7th, 2007, 08:51 PM   #2 (permalink)
wiz
£1,500 raised for charity
wiz's Avatar
Local Time: 02:30 AM
Wow,,thats a list.
Just stand your ground,I had a list of probems with mine too,some of them took 3 visits to sort.
Go get them
United Kingdom Female View wiz's Cool Blue & Dark Blue 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Sep 9th, 2007, 11:28 PM   #3 (permalink)
mikbmini
No MINI no more :(
mikbmini's Avatar
Mines got a few probs as well, including squeaking clutch, which they tell me requires replacement. They say they can't tell me if its under warrenty unless they strip out gearbox to look at it, and if its not covered by warrenty them someone will have to pay the 4 hpur labour charge for this. I just hope that they agree to cover it as I only bought the car 3 weeks ago. I'm pretty sure there must be some law saying that they must repair it as it was like it when I purchased the car from them? Its already been in to them twice on seperate issues which were wrong when I purchased it.
United Kingdom Male View mikbmini's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 10th, 2007, 10:25 AM   #4 (permalink)
TonyM
TonyM's Avatar
We had the door window seals on both doors replaced under warranty on our previous Cooper because of streaks on the glass - the dealers just replaced them with no prompting so its definitely covered by the warranty and a common problem too.
United Kingdom Male View TonyM's Mellow Yellow & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Sep 10th, 2007, 11:06 AM   #5 (permalink)
sobaphobic
my windows are a bit streaky as well, but i bought mine from evans halshaw and have a 2 year warraanty will they cover that too?
Old Sep 11th, 2007, 01:18 PM   #6 (permalink)
TonyM
TonyM's Avatar
I guess all you can do is ask them.
Ours was covered by the MINI new car warranty.
Just to clarify, these streaks were on the inside of the windows - a greasy deposit that was difficult to clean off and clearly was coming from inside the door.
Old Sep 11th, 2007, 03:28 PM   #7 (permalink)
radfordmini
Hey Cobby Park Lane. Sorry to hear of your mini problems. I had half of them on my MCS! Plus a few other niggles!
After endless visits to 2 MINI dealerships (i gave up with my local one as they were just a bunch of clowns) I lost all faith with my MCS and my MINI dealerships. Unfortunately I gave up the fight and sold my MCS this weekend! It may be the case that we are just the minority of cases with gremlins in our MINI's?
You should be able to get all the things you have issues with sorted under warranty-it's just a case of patience, time to and from the dealership to sort the problems. I also found sending emails useless and you should telephone Mini Uk and speak to your area manager.
I've bought myself a little japanese hatch back for everyday and I still have my classic Mini Cooper (which proved more reliable than my MCS) for the weekends!
Hope you get your issues sorted.
An ex-MCS owner!
R
Old Sep 11th, 2007, 03:43 PM   #8 (permalink)
laura f
off out....
laura f's Avatar
Send a message via MSN to laura f
It's worth cleaning the seals as thats causing the streaks too
Thanks to Scrogg Chris.F 2nd Gen Exterior 3 Jan 9th, 2007 03:19 PM
Good Luck Scrogg popey General Discussion 15 Dec 31st, 2006 02:31 PM
Has anyone else had problems with the dealer only half-fixing problems? Clurcle General Discussion 3 May 25th, 2006 06:40 AM
