Wipac
Old Sep 8th, 2007, 12:29 PM   #1
Togusa
Local Time: 02:27 AM
Proud MCS owner!
Woooooo!!! Pictures will be incoming soon.
One main gripe. The flag sticker on the roof needs to come off because it looks grubby. Any advice how to take it off and make it all shinyyyyyy?
The car is just so comfortable. I was a grinning manic all the way home going "poweeeeeeeeerrrrrr!" :-P
Old Sep 9th, 2007, 07:27 PM   #2 (permalink)
Tigger, Eeyore & Roo
I'm Back!
Tigger, Eeyore & Roo's Avatar
Congratulations on the new MINI
To remove the sticker, simply heat it up and peel it off! Use either a hot air paint stripper (on its LOWEST setting), or a hair dryer if you must and heat up one small section at a time and peel it off. The heat will not do the roof any damage ;a black roof will get a lot hotter in direct sunshine in August! Just keep your fingers away from the hot air blast!
Use petrol (with care!) to clear away any traces of glue residue. Then polish that roof!
Tigger.
Unintimated and I'm back!!
For sunshine, fun and Cornish Pasties: New MINI Kernow Cornish Oggy Run 2009!
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 9th, 2007, 07:36 PM   #3 (permalink)
wiggis
Life after MINI
wiggis's Avatar
Tigger.
Goes without saying that the heat source and the petrol must be well out of each others way ........... White spirit is a lot safer and just as effective.
Also - use the hair drier, not the paint stripper The paint stripper can get the surface hot enough to, well, how can I put this ............... strip the paint ...........
You might be better off asking the local dealership to remove it for you. Probably £50 for the job, but no worries
Congrats on the new motor.
Old Sep 9th, 2007, 07:46 PM   #4 (permalink)
I'm Back!
Well put.
No, it doesn't work that way. I've used a hot air paint stipper ever since a professional sign writer showed me how to do it when I had to remove vinyl sign writing from some vans back in 1987. I have never damaged any paint then or at any other time over the last 20 years. The reason that it doesn't is because the metal panel is a much better heat conductor than the paint-on-wood that a stripper is normally used on and, as I said originally, the panel never gets close to the extremely high temparatures it would do on a summer's day in direct sun.
By all means use a hair drier if you feel more comfortable, it will just take a lot longer.....
Old Sep 9th, 2007, 09:14 PM   #5 (permalink)
wiggis
Life after MINI
wiggis's Avatar
Well you live and learn
Would still recommend a non-expert use a 2000 Watt hair drier rather than a paint stripper for safety sake.
Old Sep 10th, 2007, 03:07 PM   #6 (permalink)
I'm Back!
You're probably right there wiggis, it's a bit of a knack! The biggest problem is actually stopping yourself from accidentally cooking a finger or two!!
Tigger.
Proud new owner Pompie MINI Convertible 10 Jul 14th, 2006 01:33 PM
Soon to be another proud owner.. jcwjim General Discussion 10 Jul 8th, 2006 08:35 PM
Proud new convertible owner JRowley MINI Convertible 8 Oct 1st, 2004 01:29 AM
I Am The Proud New Owner Of..... Bonnie Scotland General Discussion 13 Nov 3rd, 2003 12:11 PM
Soon to be proud owner! ATMINI MINI Cooper S 5 Oct 8th, 2003 11:53 AM
