| WIPAC is the manufacturer. It would be much quicker and easier for you to buy a wiring kit, I would get in touch with some of the WIPAC spotlight kit sellers on eBay and see if they will provide the harness on its own ![]() Found this diagram if you fancy a go yourself... http://www.mini2.com/galleries/data/...ing_lights.jpg Legally your spots are allowed to come on with the full beams ONLY, so that's definitely possible, in fact it's the only way to wire them up legally. |
| My reply not good enough? ![]() To do it yourself you will need: An automotive relay, 30A or greater Suitable spades or a holder to connect to the relay Several metres of automotive cable rated at 15A or higher (the bigger diameter the better because of reduced voltage drop) ideally in black and red. Fuse holder 15A fuse Scotchlock cable tap connector to pick up main beam feed from headlamp Ring terminal to connect to battery Ground terminal to connect to car body Suitable spades/terminals to connect to your spot lights Basically every item as shown on the diagram I linked to earlier... |
| Legend, thanks. Thought that it may have been easier to buy all the products seperately (and cheaper - tight bugger), however like you said before a kit would be easier. Can i use any kit (maybe for Ring lights) or does it have to be for WIPAC ones? Any body got any pictures of fitting the lights - step buy step diagram, ie- cutting bits off, screwing where etc... Thanks for your help so far Martin KEL |
| Hey Martin, I have now fitted the spots - so thanks for your help in that bit. However now is the tricky part of the wiring. Just a quick question - do you know which of the 2 wires which come out of the back of each WIPAC light do i need to wire? Or if its both, where do i wire both of them up to? The handy diagram above is a bit vague when it comes to the spot light wiring?! Thanks matey KEL |
| I have a guide hear for fitting spotlights..... http://www.mini2.com/forum/exterior/...ot-lights.html Hope that helps Scott |
| Tags: help, spot lights, spotlights, wipac, wiring kit |
| Wipac Spotlights wiring.. | ScottyBoy | First Generation MINI Exterior | 26 | Feb 4th, 2012 10:47 PM |
| Wipac Spot lights and wiring | Mini Mic | First Generation MINI Exterior | 42 | Oct 2nd, 2008 08:23 PM |
| Spot-light wiring | Stevemac | First Generation MINI Exterior | 1 | Nov 1st, 2007 09:50 PM |
| spot light wiring kit | "Reedy" | First Generation MINI Exterior | 0 | Oct 1st, 2005 08:48 AM |
