Old Mar 18th, 2008, 08:08 PM   #1
Matt FT
Matt FT's Avatar
Local Time: 01:25 AM
glued on number plate?
Should I be annoyed that the dealer has glued the number plates onto my new Clubman?
Old Mar 18th, 2008, 08:16 PM   #2 (permalink)
Goonery
6X therapist
It's standard practice by dealers on many cars not just MINI , so I guess not
Old Mar 18th, 2008, 08:30 PM   #3 (permalink)
S8RAH
Away with the Fairies
I seem to remember being told that it prevents theft of plates and that the DVLA recommend it as best practice. they can be removed if you change the plates, its just harder work and means the original plate is useless afterwards.
Old Mar 18th, 2008, 08:37 PM   #4 (permalink)
Matt FT
Matt FT's Avatar
Cool, thanks guys - I feel a bit better about it now.
Old Mar 18th, 2008, 10:18 PM   #5 (permalink)
mab01uk
Also smooth plates with no unsightly fixing screws showing !
You can buy the sticky pads for fixing Numberplates in Halfords. I have pulled them off before without damaging car or plates but new secure type plates are designed to break on removal to prevent theft for cloning.
Old Mar 18th, 2008, 10:25 PM   #6 (permalink)
andrewcregan
Andrew ATC
andrewcregan's Avatar
I had my dealer remove my screwed on plates, as the screws messed with my private reg. My new plate got stuck on. The stuck on plate needed removing and replacing, and this was done without too much trouble.
I wouldn't worry about plates being stuck on
Old Mar 18th, 2008, 10:33 PM   #7 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
I thought that plates had to be screwed on by law? Perhaps I mis-read the article.
My glued on plates fell off 4 x times so I got the dealer to screw them on in the end.
Vroooom Vroooom
Old Mar 19th, 2008, 12:41 PM   #8 (permalink)
andrewcregan
Andrew ATC
Quote: Originally Posted by Aberdeen Al (original)
My glued on plates fell off 4 x times.
My dealer used a double sided sticky tape. He said if you were a bit mean with it, the plate may become loose. Mine had loads put on and was secure
Old Mar 19th, 2008, 01:13 PM   #9 (permalink)
Aberdeen Al
It fell off twice between the BMW tech driving the car from the inspection bay through to the customer car pick up point.........................the 2nd time he ended up rolling over the plate & breaking it
Vroooom Vroooom
Old Mar 19th, 2008, 01:38 PM   #10 (permalink)
stuvoi
stuvoi's Avatar
Mini put the wrong number plate on my car, luckily it was screwed on, so was replaced with the correct number plate without any bother.
number plate brendanminis Australia 0 Feb 21st, 2007 08:12 AM
number plate help alski Exterior 4 Jan 29th, 2007 08:37 PM
GP number plate Griffer John Cooper Works & GP 11 Nov 16th, 2006 02:32 PM
New Number Plate? snuffy Exterior 5 Jul 12th, 2006 10:49 PM
