cd changer prep - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 27th, 2002, 02:40 PM
Chalky's Avatar
Local Time: 04:14 PM
Scotland
cd changer prep
My local Dealer put in the cd changer prep and I have just been given a slightly used BMW 6 disc cd unit. So where do I find the wires to connect?
Old Sep 27th, 2002, 03:01 PM
monsta's Avatar
MINI2 Global Moderator
Local Time: 05:14 PM
United Kingdom View monsta's Chili Red & White 1st Gen MINI Cooper Profile
Welcome to MINI2
Try this thread:
http://www.mini2.com/forum/showthrea...threadid=14557
the MINI has gone...
Old Sep 27th, 2002, 03:14 PM
Chalky's Avatar
Scotland
Just what I was looking for - tried to search earlier although search engine required minimum 3 letter words!
The good news is that the cd changer is compatible but I have just checked under the carpet and the cubby holes - no prep wiring! Will call dealer tomorrow am.
Old Sep 27th, 2002, 03:25 PM
monsta's Avatar
Good luck, it seems quite a few MINIs are without the prep...
Old Sep 27th, 2002, 03:45 PM
src
Local Time: 11:14 AM
You have to look carefully. The CD wires in mine, which was delivered Tuesday of this week, were taped with to other wires masking tape behind the little service hatch above the rear right wheel well in the boot. They were laying on top of the wheel well. To make them usable, you simply need to untape them and then feed them down inside and behind the plastic wheel housing. It's difficult to imagine that MINI would be making two different versions of a wiring harness, one with the CD prep and one without.
Dark Silver MCS w/Whte roof and mirrors
Picked up on 9/25
Premium, Sport, & Cold Weather Packages
Black Leather
Navigation
16" all seasons w/ 5-stars
Alarm System
Old Sep 27th, 2002, 04:21 PM
Chalky's Avatar
Scotland
cd prep
That's amazing!
Having checked again, you are absolutely right. The plugs are hidden below the masking tape, the larger one just barely visible.Could have spent hours trying to find them without your help. Now all that I have to do is to work out how to mount the changer properly.
Old Sep 27th, 2002, 06:15 PM
United Kingdom View ricardo's Chili Red & Body Color 1st Gen MINI One Profile
CD Changer Prep Kit Changed
I had a changer unit fitted this week during the first oil service. The car (Dec 2001 build) already had the prep kit which I'd specified when ordering. To my surprise, the technician told me that the dealers are no longer using that particular prep due to problems it's caused with the electronics. Instead, they used an entirely new set of leads that came with the changer!! Result: higher labour costs than should have been the case. On the plus side, the cost of the unit itself was much lower than I'd expected so it sort of evened out.
Old Sep 27th, 2002, 06:21 PM
src
Installation
I'm glad you were able to find the wires. With respect to the installation, each different cd player has a fairly straightforward way for doing this. If as you say you have a bmw cd player, it should be identical to the mini player, unless it is an older model. If it is a fairly recent model, you should be able to go to the parts department at your MINI/BMW dealer and purchase a cd player installation kit. The kit comes with a mounting frame and screws/bolts and nuts to install the player safely and protect it from other things in the boot. I hope that works.
Happy Motoring.
Picked up on 9/25
Black Leather
Navigation
Alarm System
Old Sep 29th, 2002, 11:38 AM
Chalky's Avatar
Scotland
Is there a preferred location for mounting the changer unit?
Presumably it's going to get knocked about a bit if it's exposed to hiking gear etc.
CR/B MC Red/Anthracite Int,MFW,Pepper,ASC,+ bits n,pieces
Old Sep 29th, 2002, 12:31 PM
One of the options in the Mini Configurator program is to include a CD changer when you're configuring your Mini. When you select the option, the picture below appears. Looks like it's mounted in the boot up against the right-hand side.
Old Sep 29th, 2002, 01:23 PM
Chalky's Avatar
Scotland
The picture above makes sense, except for the fact that my BMW unit could not fit flush to the carpet as there is a protrusion on the base(housing female connectors and fuse). Unless, of course, I simply cut a hole in the carpet area, which may be what has been done in the above picture. It is even possible that my Dealer will install for a modest charge??
Old Sep 29th, 2002, 01:36 PM
monsta's Avatar
As stated in the other thread, you can buy the parts needed to fit the CD changer from your Parts dept.
It costs about £15 , these are the parts:
1 x Bracket - 65 12 6 912 286
4 x Screws - 88 10 0 141 191 (to attach the changer to the bracket)
3 x Self Tapping Screws - 51 45 8 236 618 (to attach the bracket to the bodywork)
The result looks like this: (minus the MINI sticker )
Old Sep 30th, 2002, 10:12 AM
Chalky's Avatar
Scotland
Almost there! - thanks for all your posts.
Still trying to figure out how to feed the wires behind the plastic fascia - seems to be no room at all, so in the meantime I have simply made do with a loose fitting cubby hole cover (as per pic). Main thing is that it all works.
Old Sep 30th, 2002, 03:52 PM
United Kingdom View MINIALEX's Dark Silver & White 1st Gen MINI Cooper S Profile
Wow - u've got a red boot!! I have never seen this before, makes me wish i'd gone for red inside instead of black! Back to the point, what is the model of the CD Changer as I want to buy it from my local ICE shop? Thanks
Cometh the Hour, Cometh the MINI
  #15 (permalink)
Old Sep 30th, 2002, 04:36 PM
Chalky's Avatar
Scotland
It's a BMW unit (15 months old) which a mate of mine had installed in a hired 3 series - didn't need it when his Company car arrived. It's not the most up to date model as it skips going over sharp bumps, but who care as it was a freebie - cost me £13 for the fixing bracket and the guy was pleased that it actually works in the Cooper.
As for the red boot, here's what the front looks like - cool??
cd changer prep bazMCS First Generation Interior & Ice 0 Nov 4th, 2006 10:50 AM
CD Changer Prep? MarkW19 First Generation Interior & Ice 4 Jul 29th, 2003 10:37 PM
MD Changer using CD prep stephen_cy_wong First Generation Interior & Ice 2 Jun 13th, 2003 01:03 AM
Cd Changer Prep? Minielium First Generation Interior & Ice 3 Mar 19th, 2003 04:32 PM
CD Changer prep Skim First Generation Interior & Ice 1 Aug 28th, 2002 12:29 PM
