| Funny noise when i pull away in 1st gear Hi... I wonder if anyone could shed some light on this annoying noise i get once in a while until my car has warmed up when i dont get it. Once in a while whilst pulling away in 1st gear only i get a noise that i can only say sounds like a eeeerrrh rubber noise ( similar to like a belt slipping) it happens one day and then it wont. It happens when i am bringing the clutch up in 1st gear when pulling away. I have tried changing the gear box oil as a Bmw TECH TOLD ME TO BUT TO NO AVAIL. The noise seems to come from near the clutch pedal gearbox area. Cheers |
| http://www.mini2.com/forum/faults-fi...ml#post3675148 Try this post I had the exact same problem, got worse the longer i had the car, took it to the garage they couldn't hear the noise i was talking about (don't know how, it did it almost every time i pulled away) but said as the clutch was abit heavy they would replace it under warrenty and hopefully that would sort my problem. The next day it made the noise twice but not half as bad as it was, and its never done it since that day! And that was over 6 months ago now Laura |
| Yes mine too on 04 One Diesel. Clutch release bearing BMW advised as well but wanted contribution from me to replace clutch & potentially box, though car under TLC. I declined & have done 50k since on it no worries, not got any worse, but always noisier when cold. |
| Ticking noise on 1st, 2nd gear or neutral | vokey_sg | First Generation Faults & Fixes | 3 | Dec 13th, 2008 02:08 AM |
| 2007 MINI COOPER R56 sticky gear change 1st to 2nd gear | hankdu | Second Generation MINI Cooper | 1 | Aug 31st, 2008 08:17 PM |
| exhaust crackle & clunk noise between 1st and 2nd gear | Gr1zzLy | First Generation MINI Tuning | 3 | Jul 4th, 2005 09:19 AM |
| 1st gear belt grinding-ish noise | bluetoothmini | First Generation MINI Cooper S | 8 | Jun 10th, 2005 10:57 PM |
| Gear-stick vibrates wildly in 1st gear? | waynef | First Generation Faults & Fixes | 41 | Apr 29th, 2004 10:26 PM |
