same difference in depreciation - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 20th, 2009, 08:09 AM
Local Time: 06:15 AM
United-Kingdom same difference in depreciation
Quick Question:
If I were to buy a cooper S specced to 25k OR a WORKS with same spec so like approx 27500….When I go to sell the car in say two years time…would I get the 2500 more for the works than the cooper S….That is…would the depreciation be the same percentage or at least similar?
Old Jun 20th, 2009, 08:12 AM
PK5
they reckon the percentage is 43% loss over 3 yrs
Old Jun 20th, 2009, 08:55 AM
Paul's Avatar
MINI2 No.1
Local Time: 05:15 AM
England Male
In terms of depreciation the higher the spec, the more of the value of the options you'll lose. So a JCW having a higher "base" value should, in theory, be worth more than an S of the same overall initial cost (more options on the S to lose value on).
Old Jun 20th, 2009, 08:58 AM
PK5
also depends what the market is pointing at, if you want a high mpg then you wouldnt go for a works.
Old Jun 20th, 2009, 09:28 AM
still learning
Scotland Male
Paul is right............it's like comparing a cooper S with a cooper, the S will always have a higher base value than a cooper.
only thing is the JCW could be more desirable ( supply and demand, etc ) than an S so may hold it's value a bit better.
Tags: , , ,
Depreciation?!? Mike Edwards First Generation Works 16 Dec 17th, 2008 06:48 PM
Depreciation... Sooperlids General Discussion 12 Jul 3rd, 2005 11:03 AM
Mini Depreciation Wuxley General Discussion 8 Jun 13th, 2005 09:54 AM
JCW Depreciation bazooka joe First Generation MINI Tuning 0 Mar 5th, 2004 06:56 AM
Predicted UK depreciation Red & White Cooper 2 General Discussion 5 Mar 28th, 2002 12:33 PM
