| 1. True to an extent I did give bad advice. I admit that, although having sold these cars for four years I have only come across this problem a few times and as mentioned it has happened to me too and I rectified this by pulling harder on the handbrake when leaving the car parked on a slope. 2. Yes I did as I was not aware of the OEM rotator pad fault 3. Sorry to mislead - I'm no expert by any means. 4. Didn't mean to come across with a flippant attitude and thankfully the only harm came to the MINI And the MINI handbrake is fantastic....for handbrake turns |
| whoa whoa whoa... , I don't think that sales man was trying to offend anyone at all! In fact, I think he's just making a point and didn't really mean to upset anyone here! You see, from my experience, the handbrake does work only if you pull it all the way to the top (as Mini sales man has mentioned). Of course, in order to guarantee the car won't roll backwards would be to utilise first gear whilst parked. In my opinion, having my Coop for over 2 years now, I always double check first whether the car rolls back as I frequently park on a slope. If it does, even the slightest, then I pull higher on the handbrake (on the top click). You see, the advice regarding first gear and turning the wheel whilst parked on a slope, for me, would be advice for older cars, for instance a car from the 1990s (my other car, a 1999 Micra, I would always engage in first gear). I'm not trying to cause havoc here, please understand, but I just feel that Mini sales man has been condemned as others have misunderstood what he wrote. Its just that the Mini's technology is ever evolving, and so its brakes are of a particular standard. That, and I wanted to write something on here, cause my tumbler (what I call my Mini) has finally returned, . |
| Uhmm.. I just made a comment about him being off base and we had a debate. I have not "condemned" him. As for the advice you speak of, it has not changed just because you have a newer car. It is still a fail safe to keep the car from rolling out of control down a hill and MINI's brakes are based on technology that has been around for decades. Rotors and calipers haven't changed in a long time. The fact I am trying to make is this.... If you park a car and only apply the handbrake and it fails thus rolling back and killing someone, you are going to be held responsible even if the brake was pulled. MINI will not... We have also heard many reports of MINI's rolling and if you scour the web you will find that this is common on cars with rotors all around. Older cars actually were better off with drums to be honest. I believe that MINI has a safety issue in this area. The one that I checked was all the way up and I could pull it any further. Oddly, I released the break, started the car, pumped them a few times and then reset the brake and all was fine. The owner got rid of it because he no longer trusted it. So, to MINISalesman, I am sorry if you think that I am singling you out. I simply took offense to the fact that you were pinning the full blame on the OP when there clearly is shared blame here. Search this site and you will see that it is a common occurrence. No condemning needed. |
| That's certainly fair doos, Mr DaFlake. I would agree that older cars were better off with drum brakes: what about nowadays? What's you opinion on drum brakes on modern cars? If I can give an example: I was driving a Ford Focus (09) for about 2 weeks (courtesy), and the brakes were absolutely appalling! Front end had discs but the rear end had drums. It came to the extent that I nearly had to do emergency braking in order to stop the car! God, I hate Fords... |
| Discs are great for driving and the standard concept has not changed in years. However, we are talking about parking. The drums held better for parking. You can go to other forums and find where cars have released after being parked for a few minuets even with the brake fully applied. It happens if the conditions are right and sadly the only thing that will stop it is by putting the car in gear. Turning your wheels can also help as you will hit the curb (if there is one) if your transmission fails to hold the car. Bottom line is that you should never park the car without leaving it in gear.... |
| I completely agree with DaFlake on this one. I feel sorry for people who aren't aware handbrakes can fail, don't leave their cars in gear, and subsequently roll their car. However to give advice that there's no need to leave a car in gear on a slope as long as you pull up the handbrake a little more is completely irresponsible and could prove dangerous. Most handbrakes don't fail (so most people will be fine just pulling it a bit harder) but why would you risk your car, or the life of someone else? It can be that serious. At least everyone reading this thread will now know how to park, and if they choose to ignore the advice, one has to question whether they should own a licence. |
| ***try reading the highway code. ***doesn't say too much if you are not aware of such a common issue (or limitation) of the MINI's design (disks all round) after 4 years of selling them. ***frankly after selling them for 4 years you should be - don't you think? *** ![]() *** great.....on the public road in cars you later sell as "demonstrators" I assume? Mmmmmm |
Woops!!! Wow, I didn't intend to cause problems here....Sorry!!! Thank you all for your advice and comments. ![]() I have used first gear since this 'little accident' and hopefully I won't have further problems. If anything comes out of this expensive incident...I hope other's will apply/ use first gear as a matter of course. I have never had to on any of my other cars....but hey, expensive lessons learned!!!! I will have to wait another month before I purchase a new pair of Christian Louboutin shoes ![]() Mini will not move on this one as expected!!!! Thank you all once again. I think debates like this are healthy anyway. Life would be so boring if we all held the same views.... |
| Mini Handbrake Failure!!!!! | Antony08 | Second Generation Faults & Fixes | 23 | Apr 13th, 2011 10:00 PM |
| Handbrake Failure | Xena | First Generation Faults & Fixes | 30 | Jul 30th, 2006 04:56 PM |
| Handbrake failure on my two week old cooper.s | Gary.J | First Generation Faults & Fixes | 31 | Jul 21st, 2006 10:57 PM |
| HAndbrake Failure | wow | First Generation Faults & Fixes | 2 | Jan 26th, 2004 02:18 PM |
| Handbrake Failure | diverse | First Generation Faults & Fixes | 18 | Feb 27th, 2003 06:30 PM |
