How do I reset my mini one after changing brake pads? HELP! Hi,can somene PLEASE help me!!! I have a beloved mini one 2007, and need to know how to reset it after changing the brakepads- as don't want to pay mini 40 pounds for it;-) There was a post on this forum but we tried that and it didn't work? Thanks |
| If the sensor has activated, it means that you need a new one. These aren't expensive (£12ish + VAT?) from a dealer. Due to their design, they're single use - so once the change brake pad light comes on you'll need to replace the sensor. Really, you should be changing pads before it comes on - it's just your safety mechanism that costs you a cheap sensor rather than an expensive disc at the last minute. ![]() Once this is changed over, a little bit of driving should be sufficient to turn the brake pad warning light off. All the best, Andrew. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| Tags: brake pads, change, mini one 2007, myself, service |
| Changing brake discs and pads | jackscoopers | First Generation MINI Cooper S | 2 | Jun 13th, 2009 11:38 AM |
| Changing front brake pads | firetramp | Wheels, Tyres & Brakes | 4 | Apr 14th, 2009 06:05 PM |
| Brake Pads Need Changing | theminiv | First Generation Faults & Fixes | 2 | Oct 16th, 2007 07:33 PM |
| When changing Rear Brake Pads | anthony.manders | Wheels, Tyres & Brakes | 0 | Dec 2nd, 2006 04:41 PM |
| Changing rear brake pads | Sushi | Maintenance & MINI Care | 6 | Sep 1st, 2004 04:42 PM |
