'Engine Oil Pressure too Low' - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 11th, 2009, 06:36 PM
Local Time: 06:24 PM
Just driving home from work tonight I little oil warning light came on. Looked it up in the manual and it says the oil pressure is too low. It also says you should stope the car immediately and consult Mini Service. I'm a bit scared to drive it again over the weekend. The Car is a 57 plate One. I'm getting a Cooper S in the next few weeks so could really do without the hassle of my current car going wrong!
Old Sep 11th, 2009, 07:17 PM
DaFlake's Avatar
MMC Member
Local Time: 02:24 PM
Do not drive it.... Starving the engine of oil could destroy it. You need to get it checked out.
Old Sep 14th, 2009, 10:55 PM
The Eggman's Avatar
Local Time: 07:24 PM
United Kingdom Male View The Eggman's Dark Silver & Black 1st Gen MINI Cooper S Profile View The Eggman's Classified Ads
Checked oil level, I'd think you where very very low, oil pump failure is rare. Do you check oil level regular ?? Just like petrol a car uses it.
Old Sep 15th, 2009, 10:22 AM
United States Female
Hello,
Hey friend i have also been in a same situation, just don`t drive it now, if you will keep driving it, it may cause big damage to your engine resulting in long silence that mean it could kill your engine.
Regards,
sarah_9
Tags: , ,
low pressure light. Mini HeHa Wheels, Tyres & Brakes 3 Sep 8th, 2008 07:04 PM
Idle oil Oil pressure 0 psi!!!!! acebedof First Generation MINI Tuning 4 May 29th, 2006 03:20 AM
Oil Pressure Light After Oil Change tpwmini First Generation MINI Tuning 6 Apr 20th, 2005 02:50 PM
Oil Pressure Light after Oil Change tpwmini First Generation Faults & Fixes 0 Apr 16th, 2005 03:46 PM
low oil pressure Bob Jacobson First Generation Faults & Fixes 1 Mar 6th, 2003 03:20 PM
