have a ? about what switches do what - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Nov 24th, 2009, 03:01 AM
Local Time: 05:55 PM
United States Male View Anitan1's Chili Red & White 1st Gen MINI Cooper S Profile
Quote: Originally Posted by beken (original)
As I understand it, most people remove the fender liner inside the wheelwell to get at pretty well anything. Though I've never done it myself, I am under the impression that removing the fender liner is as simple as popping the 3 or 4 plastic hold down rivots and easing the liner over your wheel.
Beken, Thanks a ton!
I wondered if that's what I'd have to do in order to do the install, but I wasn't sure how easy/hard it would be... I need to replace the backup light switch anyway, so maybe I'll do both jobs at the same time. Should be a great way to spend a Saturday... I think I'm gonna go ahead and do the whole factory install with the new wiring harness as well. If I'm gonna do it, I want it to be right.
  #17 (permalink)
Old Nov 24th, 2009, 08:57 PM
beken's Avatar
Send a message via ICQ to beken Send a message via MSN to beken Send a message via Yahoo to beken Send a message via Skype™ to beken
Local Time: 02:55 PM
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
Just a word of warning, the foglight sequence needs to be programmed in the ECU. After you've done your install, you may still need to bring your MINI into a dealer to have the lights programmed in. I'm not sure how much your dealer will charge to do that. It might be an hour's labor unless you do it with a whole bunch of other stuff.
05MCS BEP Alta 22mm rear anti-swaybar, Madness CAI, Alta 15%, NGK BRK7EIX, M7 Strut Tower Reinforcement plates, BSH Lower Engine Mount
Switches hedcase38 First Generation Interior & Ice 10 Mar 21st, 2005 04:14 AM
how many switches? etickt General Discussion 1 Nov 23rd, 2004 08:58 PM
Switches and more Switches Mugami First Generation Interior & Ice 0 Jun 21st, 2004 03:47 PM
Switches Phrozen General Discussion 8 Nov 20th, 2003 11:53 AM
switches curryman77 First Generation Interior & Ice 3 Jun 26th, 2003 04:37 AM
