| The Megane would have an open diff meaning that the torque would just end up going to the wheel with the least grip. With the LSD in the MINI, if one wheel is on ice and the other is on tarmac, although the wheel on ice will still spin, some of the torque will be channelled to the wheel on tarmac. Of course, if both wheels are on ice/snow, then the LSD will probably not help at all. I've been finding that my LSD makes the car do wierd things on ice/snow. As the LSD makes both wheels spin up, the car slips sideways quite often and makes peculiar groaning/ticking noises. |
| I reckon there's an age issue at work here - old farts like me generally forget that the 'kids' has very little experience of driving on snow. When I moved up to the North East from 'doon sooth' nearly 30 years ago, a fortnight of snow lying on the ground was completely normal but there's a generation of drivers who've grown up without that, thanks to global warming. It's amazing how many drivers think that if the driving wheels are slipping on snow or ice, flooring the throttle is the right response! But it ain't all age by any means - a neighbour hasn't used his BMW X3 4x4 because "the roads are too dangerous, why risk it?".... ![]() Andrew |
| iv got a tuned cooper s with the works wheels and yokohama s drive tyres in sheffield 6inches on snow and had less trouble that 4x4s u just had to turn traction control off if u see a hill coming build ur speed up before so u dnt loose momentum n just end up polishing the ice! i even went out yesterday to the peaks to find snow covered roads to do abit of handbrake drifting didnt get stuck once n these road where hairy |
having had cars for many years, i cant really say any of them have been too good in the snow (not that we usually get snow ) when on normal tyres however, i did find the mini (sidewalk convertible) to be relatively good on packed snow. I have never had Winter Tyres but if this snowy weather persists, then maybe this is the solution. |
| If you're referring to my post, you've missed the point. Of course full throttle is completely inappropriate in these conditions; the point is, however, traction control systems are continually improving - feeding just enough power to match available grip, full throttle in slippery conditions being the casing point. The problem with modern cars is that they feel falsely secure. e.g. people don't know how to brake on ice (ABS won't help you). |
| No, not at all - I was mostly thinking of a lad in a Corsa that took a couple of minutes to get out of my way this week - maybe he'd seen some rally video, as on deeply treaded tyres on soft ground, I think max wheelspin and power is actually the right way to go, as long as you're still moving. I ain't gonna argue with the leading Dakar guys, who all seem to deal with soft sand this way. I read a Prodrive chassis engineer's fascinating understanding of the driving habits of the general public. For example, many drivers never drive outside the linear range of their vehicle - ie, if I want to turn a bit sharper, I turn the wheel a bit more, etc - and if they ever go past the linear range, they deduce that their vehicle is broken as it doesn't respond correctly. Amazingly many of these drivers then just wait for the crash - after all the controls no longer work properly, so why use them? In some cases, they even go so far as to take their hands off the steering wheel. There is a wonderful term for this which I will never forget: "control abdication". And this is who we share the roads with..... Andrew |
| I have to say, my Cooper (R50) is the best car i have had for the snow. Running on 17"s with run flats and it hasn't missed a beat in the snow - And i absolutely hate driving in snow. Only problem is, i seem to be the lowest car around my area, as i continually scrape the middle mound (between the tyre ruts) of snow flat - and the car's not even lowered!!!! It's not mission difficult Mr Hunt, It's Mission Impossible Mission difficult should be a walk in the park for you.... Mission Impossible is trying to get your wife to understand that we really do need a Cooper S |
| Snow in the UK - Feb 2009 - have you bought snow chains? | Jinkster | Wheels, Tyres & Brakes | 3 | Feb 12th, 2009 12:40 PM |
| Mini's And Snow Boards | Manickane | First Generation Interior & Ice | 5 | Dec 8th, 2008 07:16 PM |
| What a bunch of rubbish!! | Christian USA | First Generation Works | 2 | Sep 19th, 2006 12:29 PM |
| Snow Covered MINI's | Minty | General Discussion | 41 | Jan 13th, 2003 05:39 PM |
