mini roof respray options - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 10th, 2011, 09:17 PM
Local Time: 07:31 PM
I am soon to take delivery of a nearly new mini one in interstate yellow. I would prefer it to have a black roof.
I phoned around thrfee body shops who all quoted around £200.
When I phoned a couple of mini dealers they quoted around £400.
When I asked why the difference, the mini dealers said that for £200 the bodyshop would simply spray the roof without removing the window rubbers, in time rainwater gathering at the edge of the rubber would cause the paint to peel. They explained they would remove the window rubbers, spray then refit.
Are the mini dealers correct and would a £200 bodyshop respray without removing the rubbers cause problems over time?
Old Jun 10th, 2011, 09:29 PM
Cooper S newbie
Black Cooper
Its completely upto you, the mini dealers would do all the work for you, but i dont see why you couldnt just remove the rubber yourself or get a window specialist out for £75 quid.
Alternatively, your gonna save 200 bucks by going with the bodyshop, so if worst comes to worse youll have the other 200 bucks to get it sprayed again! thus making the roof look brand new again!
I would have thought youll get at least 3/4 years out of the roof before it decides to peel.
Hope this helps!
Old Jun 10th, 2011, 09:33 PM
minicore's Avatar
Super Moderator
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
How about getting it vinyl wrapped?
Old Jun 10th, 2011, 09:35 PM
Cooper S newbie
Excellent idea dude!!
Vinyl wrapping would be a lot better than paint! and last longer, and probably be cheaper.
I was quoted £900 for a full car a few months ago, so a small mini roof would probably be about £200.
Old Jun 10th, 2011, 10:14 PM
minicore's Avatar
Super Moderator
Vinyl wrapping certainly won't "last longer", after all painting is permanent, whereby a wrap will allow you the option to revert back at any point (or re-wrap in another colour).
Old Jun 10th, 2011, 10:31 PM
Cooper S newbie
England
I meant in terms of fading, vinyl wont fade in the sun where paint will.
Old Jul 8th, 2011, 03:36 AM
Local Time: 02:31 PM
I would first ask the body shop if they would remove the rubber, if not I would go with a vinyl if it cost less than 200, i wouldnt pay the same for painting it as vinyl as that just seems silly.
Old Jul 8th, 2011, 03:57 AM
http://www.mini2.com/forum/general-d...roof-wrap.html
Tags: ,
Mini Respray Meeny Second Generation MINI Exterior 3 Jan 28th, 2011 10:13 AM
R56 roof bar options woofboxer Second Generation MINI Exterior 0 Oct 9th, 2008 09:45 AM
06 Roof Rack Options? Herbster First Generation MINI Cooper S 0 Aug 15th, 2006 02:15 PM
New options - decals, fabric roof... Paul First Generation MINI Exterior 5 Nov 6th, 2002 11:36 AM
USA roof options S2000&CooperS General Discussion 1 Feb 13th, 2002 11:45 AM
