Driver door will not open from inside or outside - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 6th, 2011, 09:52 AM
Local Time: 05:02 AM
Australia
Australia Driver door will not open from inside or outside
Can anyone help me I have a 2006 mini my driver door will not open. First it opened from the inside only but now I canny open the door at all so am having climb through the passenger door to get in my car.
The locking mechanism seems to be fine. One my friends was going to take a look at this for me but as the door won't open he cannot take the trim off to see the cables.
Can anyone help please
Old Oct 6th, 2011, 06:31 PM
Eirik's Avatar
Local Time: 08:32 PM
Norway Male
It seems like you have to remove the door trim with the door closed, dont think it will be a big problem on a Mini. Just push the driver seat back all the way and loosen the 3 bolts on the door trim and pull it off.
RealOEM.com BMW R53 Cooper S Door trim panel
You have to remove Nr. 12 to find the third bolt
I think your problem is mechanical so see where the wires go and check if its connected and so on
RealOEM.com BMW R53 Cooper S DOOR HANDLE FRONT/LOCK, SINGLE PARTS
Check Nr 10
Tags: , , ,
I cant open my door from inside by pull the handle twice.. NiuNiu First Generation Faults & Fixes 0 Jun 2nd, 2011 07:32 AM
Unable open passenger door from inside! andykb First Generation Faults & Fixes 3 Jul 8th, 2009 07:08 PM
dodgy door handle ... door not opening from inside baloo247 First Generation MINI Cooper S 1 Aug 17th, 2008 02:25 PM
Can't open door from inside KeyserSozeSLO First Generation Faults & Fixes 7 Jun 5th, 2007 06:41 PM
Unable to open driver door! ~sugar~ First Generation Faults & Fixes 14 Sep 14th, 2003 06:18 AM
