start stop system - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 19th, 2011, 08:14 PM
Local Time: 07:32 PM
start stop system
Bought a three year old mini cooper s a couple of weeks ago and the start stop system hasn't kicked in since day three. Booked it back into the garage twice and they're now telling me these little cars are temperamental and only work under very strict conditions. Anyone else experience of this or am I being fobbed off
Old Oct 19th, 2011, 09:29 PM
dlpruk's Avatar
United Kingdom Male View dlpruk's Oxford Green & Body Color 2nd Gen MINI Cooper Diesel ALL4 Countryman Profile
This time of year, the s/s should kick-in as soon as the engine is warm - say after 3-5 miles of driving.
It doesn't work in very cold weather though.
There's a long list of things that cause the stop/start not to operate - like the engine's still warming up, the outside temperature is low, etc.
The one that I'm pretty sure is preventing my stop/start from working right now is the condition of the battery - if I charge it up fully on a battery charger (any car's alternator is a bit weak by comparison), the stop/start works but after a few months it doesn't. Right now, if I drive 50 miles, that's enough to charge up the battery and the stop/start will work, but around town it doesn't charge enough.
I can't tell in daily use that the battery isn't very strong - the car starts with enthusiasm - but its behaviour when being charged told me it's got a bad cell. So it's pretty borderline, but that's enough to let the voltage drop to the point where the BCU won't let the stop/start operate.
This seems quite a likely problem for many cars, so if you want to test it out on yours, use/borrow a battery charger and see if the stop/start comes back.
Another stop/start test I've seen is 'cabin not at temperature', so make sure your heater or A/C isn't set on maximum (either way) as I've found that can do it too.
Old Oct 28th, 2011, 05:39 PM
If it is still under warranty take it back and demand it fixing why should they even be able to fob you off if there is a problem with a 20k car it needs sorting
Old Oct 28th, 2011, 08:28 PM
My stop start works from coldish, ive had the car 4 months and it has never failed to kick in at the first set of traffic lights that are only half a mile from the house, I know its stone cold but still operates, the only time it doesnt is when it regens the particle filter....
Old Oct 28th, 2011, 08:37 PM
Local Time: 06:32 PM
Yep my clubman only takes 5-10 minutes to warm up before the auto stop start kicks in.
Old Nov 3rd, 2011, 03:16 PM
England
My car's brand new and the start/stop seems to work when it wants to. There's no rhyme or reason that I can work out as to why it sometimes works and other times - about 40% of the time, doesn't.
I stop the car, take it out of gear and lift the clutch - it then may work - if it wants to.
It doesn't seem to matter if the engine is warm or not.
Old Dec 8th, 2011, 02:07 PM
I can get the stop/start to work much more often by switching the heater fan off - obviously higher electrical load in the circuit keeps the engine going.
Old Dec 8th, 2011, 06:41 PM
England
Might sound like a stupid point to make,but if you reverse your car off the drive without putting on your seat belt before moving the stop/start does not work. - make certain you buckle up before moving.
Worked for someone else who posted the same problems.
Start / stop function minimum stop!? Swami General Discussion 6 Jun 17th, 2011 09:10 PM
So where did my stop/start go? Angib Second Generation MINI Tuning 4 Apr 12th, 2011 10:00 PM
Start/Stop? benwilly Second Generation Faults & Fixes 13 Jan 29th, 2009 01:03 AM
Stop Start System daro911 Second Generation MINI Tuning 19 Jan 28th, 2007 09:33 AM
Car won't start; fan won't stop! ignomini First Generation Faults & Fixes 7 Jul 26th, 2006 03:16 PM
