1st Gen Exhaust issue - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 18th, 2011, 06:21 PM
Local Time: 01:33 PM
DIY 1st Gen Exhaust issue
My '04 R50 with 86K now has a loosetailpipe and is beginning to make an odd noise that I am not sure is exhaust related.
It makes atapping sound that only comes under load (excellerating or decellerating, but not with the clutch in). At first I thought it was the exhaust, but I am beginning to wonder.
No performance drop noted by the way.
Anyone have any ideas what is going on? I know I need to do something about the exhaust (hopefully just a hanger issue).
Also, what is a good replacement Exhaust system (cheep) and how hard is it to replace my self (without a lift)?
Thanks...Bill
Old Nov 18th, 2011, 07:30 PM
DJ_Scooby's Avatar
Local Time: 06:33 PM
United Kingdom Male View DJ_Scooby's Classified Ads
first thing to do is give the exhaust a good look over and wiggle it about, it should help eliminate the exhaust if its found to be in a solid state when wiggling.
Old Nov 18th, 2011, 11:39 PM
mab01uk's Avatar
Local Time: 07:33 PM
The rear exhaust brackets/straps are prone to rust corrosion and worth checking for security as it can damage the complete exhaust system if they let go suddenly........the rear silencer box is quite heavy if it drops.
Diagram of exhaust:
RealOEM.com BMW R50 Cooper Exhaust system, rear
Tags: ,
Nov/Dec 08 issue of MC2 - Whose car? beken Canada 1 Dec 25th, 2008 06:05 AM
MC2 issue 6 velveteen_mini Canada 13 Feb 12th, 2007 03:54 PM
My cold start issue is now a warm start issue FrenchCori First Generation Faults & Fixes 0 Mar 31st, 2006 10:39 PM
Any one buying Miltek exhaust from amd beware ( ANOTHER MILTEK LOOSING BOLTS ISSUE) Black&WhiteScooper First Generation Faults & Fixes 35 Mar 26th, 2005 11:38 AM
