Niggles - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 7th, 2011, 12:07 AM
shilts's Avatar
Local Time: 06:34 PM
United Kingdom Male View shilts's Chili Red & White 1st Gen MINI Cooper Profile View shilts's Classified Ads
Niggles
Picked up new r56 cooper s jcw this week and 2 things that arent quite right!
Firstly parrot kit was fine when I collected the car however when you go over a bump it tents to switch itself on/off. Obviously it will be a loose connection with the power supply. The kit is mounted next to the starter button...any ideas how to fix?
Secondly power steering makes a nasty noise at low speed on lock...thought it was electric steering on this one so I don't have a clue what that can be!
James
Old Dec 7th, 2011, 04:10 AM
BlueBeastie's Avatar
Local Time: 08:34 PM
South Africa Male
Hi
If you bought from a dealer, then take it back to have the kit checked out, you might spend hours trying to find the loose connection.
As for the power steering, it usually is noisy on lock, but you feel uneasy about it then take it to your local dealer.
Tags: ,
Niggles bobbydazler MINI Clubman 0 May 6th, 2011 07:00 PM
Few little niggles CooperSChic Maintenance & MINI Care 1 Dec 6th, 2010 06:35 PM
few little niggles linuxpro First Generation Faults & Fixes 3 Sep 19th, 2008 08:17 PM
delivery niggles flybynight First Generation MINI One 7 Aug 14th, 2003 10:37 PM
Niggles- but that's all. robinboyes First Generation Faults & Fixes 0 Dec 27th, 2001 02:31 PM
