| Noise after changing clutch Hey I have just changed the clutch in my 05 Cooper and for some reason it wont go into gear properly when the motor is on, it will go in but will make a slight grunch noise, it goes into gear with out force it just does this noise and makes me think the clutch isnt coming out all the way or there is something wrong with the gearbox.. I have changed and bled through the clutch slave cylinder and don't now what it is... if you have had this problem before could you let me know?? thanks |
| Hi It sounds to me like you have air in the system from the slave cylinder change, They can be a pain to bleed http://m.youtube.com/index?desktop_u...?v=68PIYbXk1nc Hope this helps |
| Strange noise when changing down :( | Taylorcy | Second Generation MINI Cooper S | 4 | Apr 7th, 2010 04:39 PM |
| Knocking noise when changing gears | laserbluemini | First Generation Faults & Fixes | 7 | Dec 9th, 2009 12:01 AM |
| Changing my own clutch HELP !! | Wez007 | First Generation Faults & Fixes | 9 | Jul 3rd, 2009 10:22 PM |
| Strange noise on changing gear | Mini-Medic | First Generation Faults & Fixes | 18 | Jan 25th, 2008 12:29 PM |
| Changing trasmission - Flywheel - Clutch - LSD | lex76 | First Generation MINI Tuning | 1 | Dec 27th, 2004 03:24 PM |
