Dipstick level? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 21st, 2011, 11:18 AM
Local Time: 06:35 PM
Dipstick level?
Just picked up our 07 Cooper S...
The manual isn't that clear about checking the oil level...
Exactly where on the dipstick should the oil be?
( is it between the end and the first collar, or between the first and second collar ignoring the pointy end collar)
Thanks !
Old Dec 21st, 2011, 12:07 PM
Local Time: 07:35 PM
Hi
Bottom collar is min, top collar is max and the pointed end is the guide
I normaly fill just below the max collar
Hope this help
Old Dec 21st, 2011, 04:24 PM
Macguyvic's Avatar
Macguyvic
Local Time: 01:35 PM
United States Male
That dipstick looks completely different from the dipstick in my 08 Cooper S. The only part that looks similar is the plastic at the end.
Old Dec 21st, 2011, 08:46 PM
Thanks for the replies.... I'll put a bit in tomorrow in that case.....
Thought the 07/08 would have been the same but there you go
Old Dec 21st, 2011, 10:14 PM
Cooper S Jon's Avatar
same as my 07 Cooper S,when cold my oil is just above max collar..
I'd rather push my mini than drive a ford or anything french..
Criteria for buying a diesel..1)long journeys.2)motorway miles.3)minimum 14k mls per yr..
Old Dec 22nd, 2011, 06:29 AM
Mine's on the lower collar by the description... so top up definately needed
Old Jan 1st, 2012, 09:35 PM
Travels's Avatar
Female
The two marks on the dip stick represent Minimum and Maximum, the oil level should between the two marks.
oil level??? Dipstick???? dai jones Maintenance & MINI Care 3 Jun 30th, 2011 06:38 PM
oil level on dipstick newbie Maintenance & MINI Care 0 Sep 7th, 2010 12:46 PM
Oil Dipstick and Oil to use kingoftherodeo Maintenance & MINI Care 4 May 17th, 2010 06:48 PM
snapped dipstick!!! HELP removing dipstick Pipe!!! venox22 First Generation Faults & Fixes 10 Jun 7th, 2006 08:25 AM
Coolant level right on min level rainbowdreamer First Generation Faults & Fixes 2 Aug 24th, 2003 04:06 PM
