Headlight problems ![]() ![]() So I've just changed my old headlights for upgraded xenon headlights. All was going so well easy to change them no problem, when I jumped into the car to check how they looked oh dear. When the key in the ignition is turned on the lights work fine BUT when I turn the key to switch the engine on the lights cut out completly. Has anyone got any suggestions I'm trying to register my UK mini in France thats the reason for me changing my headlights. ![]() ![]() |
| I have the same problem. Had to stick the Halogen back in until I find an answer. My car 2006 Mini doing the same thing. Accessories on - lights on. Car started and running - lights off. Can you let me know what the solution is if you have one? Thanks. |
| R50 Headlight alignment problems | SlipMat | First Generation MINI Exterior | 1 | Oct 28th, 2011 08:25 PM |
| 2004 - Headlight Problems | rad_88 | Maintenance & MINI Care | 0 | Oct 16th, 2008 01:09 AM |
| Headlight level problems | stevenrollo | First Generation Faults & Fixes | 9 | Sep 3rd, 2008 12:18 PM |
| Headlight Washer Problems | Gaz-24 | First Generation Faults & Fixes | 5 | Dec 4th, 2006 09:45 PM |
| AUSTRALIAN HEADLIGHT PROBLEMS - reply here. | cityclinic | First Generation Faults & Fixes | 22 | Nov 10th, 2004 11:34 AM |
