Mini One Coolant tank cap - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 21st, 2011, 09:20 PM
MGFmad's Avatar
Local Time: 07:36 PM
How does the coolant tank cap work - generally cars have a pressurized cap but this does not appear to be the case with the Mini - what stops the cap from popping open when the coolant is under pressure with a hot engine
Old Dec 21st, 2011, 09:33 PM
Cooper S Jon's Avatar
mine screws onto the tank i've an S,so the mini 1 should be the same
what year is your one?
I'd rather push my mini than drive a ford or anything french..
Criteria for buying a diesel..1)long journeys.2)motorway miles.3)minimum 14k mls per yr..
Old Dec 21st, 2011, 09:37 PM
dsakko's Avatar
Local Time: 05:06 AM
Australia Male View dsakko's Midnight Black & White 2nd Gen MINI Cooper S Profile View dsakko's Classified Ads
Nah totally different on the Cooper / One.
They run a black pressure cap very near the throttle body. The bottle is unpressurised. Why they had two totally different designs I don't know.
The caps are rubbish and I was replacing mine yearly. After a short time they no longer hold full pressure and blow out all your coolant when hot.
R56 MINI Cooper S JCW Challenge
Old Dec 21st, 2011, 09:58 PM
that's daff the whole point of pressuring the sytem is that it raises the boiling point..
Old Dec 21st, 2011, 10:48 PM
mab01uk's Avatar
Pressure cap on One and Cooper is shown here, No.11 in diagram on thermostat housing:
RealOEM.com BMW R50 One 1.6i Waterpump - Thermostat
Old Dec 22nd, 2011, 09:49 PM
MGFmad's Avatar
Thanks for that
Do you have a coolant tank leak? Tom F. First Generation Faults & Fixes 48 Dec 11th, 2010 11:03 AM
mini cooper r50 coolant tank boiling? help fekna First Generation Faults & Fixes 2 Apr 3rd, 2009 03:34 AM
What to fill coolant tank with? PsychoChimp Maintenance & MINI Care 5 Mar 16th, 2009 12:03 PM
Coolant tank replacement??? Faat First Generation Faults & Fixes 4 Jun 6th, 2004 11:38 PM
Coolant Tank Dealer help? KenBond First Generation Faults & Fixes 10 Mar 17th, 2004 09:49 PM
